WHERE IS THE FUSE ON THOSE MODELS NN-SD277 MICROWAVE
If mounted on the wall above the range, this may be a 2-man job to remove, and the electrical repair may not be for DIYer. 1st ask "Why is fuse bad?" Usually the fuse is located with other electrical/electronic components behind the control panel. To access: unplug, remove MW from wall, remove bonnet (3-sided metal shroud), expose the electrical compartment on the right side, search for the fuse (usually 1 1/4 x 1/4D cylinder). Replacing the fuse may not be the final answer.
