Hp pavillion dv2000 won't start properly. when i press power button. i kinda boots up and blue quickplay lights come but thats it. no screen. is it in some sort of sleep mode? I press the ¨turn on¨ bottom but just the blue lights turn on, the hdd don´t run and the fan sounds good but I didn´t ear any sound(beep) just the fan....thanks.
The problem could be with your screen. It looks like the led light of your screen is dead you could follow up this solution.
I have had this same problem with a HP DV2000 and the
problem is not the contrast light. What it is, is that the laptop
thinks that the screen is been shut down that is why the light does not
come on. The best way to solve this is to remove your keyboard first.
You
can remove the keyboard by removing exactly 7 screws from your laptop
back, there are 5 screws located under your battery and other two that
are in the location of your RAM'S.
Just open them up and then
you will notice that the key board pops out abit then just simply take
it up and then just below the keyboard, on the same line where HP brand
logo is on your machine there are two small clip types of pind, that
you can remove and put back.
There is a clip that is hidden abit
under the metal plate, so just try and remove that clip from its place
using a needle or any long and thin object.
That will make the
laptop not have the problem. But once you remove that the laptop
constantly will think that the screen is open even if you close it.
then after like a week or two you can put it back and all shall be fine
if not then just remove it and keep it out.
You can then set
your power options to shut down the screen light every 2 minutes or
something like that so as to avoid the backlight being switched on all
the time.
Hope this solves your problem.
I think the problem is with your LCD screen.
Try connecting it to external monitor and see whether a display will come up on the external monitor. If this the case, update your video driver. If you had updated video driver but still no display I suspected your LCD screen is faulty and needs to be replace.
(if machine is under warrantly, no need to pay any fee for replacement).
