could be as simple as the fuse on the power supply. do you get an led on the button panel?could be as simple as the fuse on the power supply. do you get an led on the button panel?
You can't post conmments that contain an email address.
the light tunnel is collapsing and will need to be replaced. you could either get the part from an infocus service center or send it to them to repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
first try another computer cable. if same results, press the "auto image" button on the projector. if that doesn't work, press menu, select settings, then factory reset, and "yes". if you still have the same problem, the eca (main board) is bad.
A great deal of the time DVD players are very restrictive on outputting to multiple sources due to copyright protection. In my experience, if you use your laptops function keys to toggle output (For example, on my laptop, I hit FUNCTION + F4 to cycle between LCD,LCD+VGA,VGA), you should be able to disable the laptop's LCD display, only outputting via the VGA cable. It's worked for me with my HP VP6111 and Windows XP in the past.
Hope this helps!
