20 Most Recent InFocus IN72 Multimedia Projector Questions & Answers
Have you check the power source, including circuit breaker, wall outlet and power cord, and built in circuit breaker, if every thing is OK, looks like the light source (lamp) is open circuit.
InFocus IN72... | Answered on Nov 23, 2013
Could be a defective HDMI processor word of warning to everyone never under any circumstances must you connect up any device with HDMI ability whilst they are switched on as static can and indeed does smack out the HDMI processor and can and does work out expensive in time to replace.
john
www.jvsvisual.com
InFocus IN72... | Answered on Apr 19, 2013
images?q=tbn:and9gcsq3imtjhqb0abmt8dptscde8waay3n_hlomxu7sbdjgyrsqmaoxypwoa
A SCART connector is a physical and electrical interconnection between two pieces of audio-visual equipment, such as a television set and a video cassette recorder (VCR). Each device has a female 21-pin connector interface. A cable with a male plug at each end is used to connect the devices. (The 21st pin is actually not a pin but a ground shield contact.) Stereo audio, composite video, and control signals are provided in both directions. RGB video signals are input only. The interface is an industry standard
originated by the French company, Peritel. Today, most new television sets and VCRs in the European market and other countries that use the PAL video standard come equipped with a SCART connector. SCART stands for Syndicat francais des Constructeurs d'Appareils Radio et Television. The connector is also known as a Euro-connector.
Although it is possible to build your own connecting cable, knowledgable people recommend buying a commercial cable because of the detailed pin-crossovers and close pin connections. Differerent cables serve different purposes. A cable for connecting a VCR or a TV set to a high-fidelity audio system needs to use only three of the 21 pins.
It is more difficult to use the SCART connector to interconnect a VCR to a computer monitor because of the difficulty of synchronizing the composite video signal (which is companded into red, green, and blue) from the VCR with the RGB signals needed by the monitor.
InFocus IN72... | Answered on Feb 17, 2012
Hello
To reset lamp hours:
Menu => Settings => Service
In this window; you can select Lamp reset.
Press Enter or OK.
InFocus IN72... | Answered on Oct 05, 2011
Possible that the SMPS unit is faulty as it might even be a fuse failure. So it is important that you will need to open the main supply to the projector to get access to the SMPS unit.
Please click on the link below for tips on servicing the SMPS.
Click on SMPS
InFocus IN72... | Answered on Dec 24, 2010
That should be fine to do. Even if the projector did alter the current based on lamp life, the worst that could happen in the lamp would burn out completely. A good projector should have a safety circuit with a fuse to prevent damage to any internal components. You should be fine.
InFocus IN72... | Answered on Sep 01, 2010
Depending on the Version HDMI cable you using this may not work.
some units use a lower bandwith cable such as 1.0, 1.2 ect ect
Yes this does make a diffrence.
Let me know if you have any questions.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Upon setting up your equipment it is very important that you turn on the projector first. You will see a blank projection image, now turn on the computer, (confirm your cables are connected properly). When using a lap top computer you may need to disable your computer's display screen. First locate the "function" key at the top of your keypad that reads "LCD", "CRT" or it may have an icon that resembles a computer monitor. By pressing the "FN" key and the corresponding "function" key you will be able to obtain the image from the projector only. This is known as "toggling" the image. If the problem still persist, replace the 10m HDMi cable.
Take care.
InFocus IN72... | Answered on Aug 25, 2010
The best that you can look out for is to look for GROUNDING problems, loose connectors or faulty cables.
Start by checking out all cables . connectors and see if the power supply ground is well fitted to the chassis. The video or the PC connectors also must be well grounded to the main board , Look for some crack or dry solderr joints in these connectors that could bring these picture noise lines.
Howeverr if you are not able to see or get across these simple problems, i would liike to advice you to try for a exchange which will save you a great deal. Be careful not to damage the WARRANTY SEALS as the dealer may not be helpful.
I hope my advice helps you to decide. Good day
InFocus IN72... | Answered on Aug 17, 2010
if the gray lines are equal and perfect, I would say this is the graybar resolution setting and would change the screen ration to a different setting to correct.
InFocus IN72... | Answered on Aug 10, 2010
make sure the lamp door is secure. if that isn't the problem then the fuse on the power supply is likely blown and will have to be repaired or the power supply replaced.
InFocus IN72... | Answered on Jul 07, 2010
the optical engine has to be blown out. I don't recommend trying this because you need to have training to properly remove the plastics and the gears on the engine. take it to a technician. you shouldn't be billed for more than 30 min at the most, 20 min if the tech is familiar with this model.
InFocus IN72... | Answered on Jun 21, 2010
Please download the manual and see it...
http://www.retrevo.com/support/Epson-72-Projectors-manual/id/5936ag814/t/2/
InFocus IN72... | Answered on Jun 18, 2010
those dots will gradually disappear, just be patient and keep using the projector like that. Its obvious that there is nothing wrong with the projector.
With time, the whole dots will disappear.
Take care.
InFocus IN72... | Answered on Jun 15, 2010
InFocus IN72 Multimedia Projector Logo
84 questions posted
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
martin hogg
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • InFocus Office Equipment & Supplies
Most Popular Question
hdmi port doesnt picture tried
  • Office Equipment & Supplies
