20 Most Recent InFocus IN24 Multimedia Projector Questions & Answers
Take off the front bezel, then remove the screws from the lens,pull the lens out and blow it out with compressed air. Do not touch the mirror or magnifier inside. If this doesn't get all of the blemishes, then you will have to remove the top cover and then the top silver part of the engine and blow it out from the top.
InFocus IN24... | Answered on Oct 07, 2013
These models have a chronic problem with overheating. I can repair the unit for $95+shipping. email me at [email protected] if you are interested and I will give you my address to ship it to me.
InFocus IN24... | Answered on Dec 22, 2012
dmd chip replacement
InFocus IN24... | Answered on Mar 27, 2012
looks like damaged cable or bad connection
or else its faulty
InFocus IN24... | Answered on Mar 09, 2011
First suggestion is checking to make sure that the tray/chains are secure - that it's not going to fail at at a point of connection either at the ceiling or point where the chains fasten to the tray. The tray must be strong enough for the weight of the projector (most InFocus classroom projectors are not that bulky and heavy).
Hanging anything with weight from the suspension ceiling braces is not recommended. If possible, having the wire/chain continue thru the ceiling panel (a small inconspicuous hole can be made through the panel) up to actual ceiling joists or whatever material the ceiling system itself is fastened to is best & the most secure. I've used steel aircraft cable (available at any Home Depot or hardware store) in place of chain, partly because it only requires a small pencil-sized hole thru the ceiling panel, hardly noticeable.
Most hanging fixtures (theatrical lights, projectors, etc.) have a secondary/backup safety cable or strap system should the main fasteners fail. In this case, if the tray and ceiling connection is secure, a safety strap holding the projector onto the tray so it's not sitting up there loose or able to be knocked out at all should be used. This also will help keep the projector's aim aligned to your screen should something bump the tray, you won't have to readjust it. (See this link attached for an example of a strap securing a projector).
(In all cases, if you have a building or school district maintenance administrator or someone who's job description requires them to be aware of state or district safety regulations/OHSA rules, they should be consulted to make sure you're following any safety issues that may apply specific to your classroom/student needs.)
InFocus IN24... | Answered on Mar 07, 2011
Go into the the menu and incheck the ceiling box.
InFocus IN24... | Answered on Feb 18, 2011
THis could be caused by a burnt LCD immager or a large spec of fluff.
InFocus IN24... | Answered on Jan 29, 2011
InFocus IN24 Multimedia Projector Logo
53 questions posted
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
martin hogg
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • InFocus Office Equipment & Supplies
Most Popular Question
new bulb but am getting dark shadow
  • Office Equipment & Supplies
