I just replaced my Bulb and bought it on E-Bay for $199.00 including shipping. Looks like a new one!!!!!! A new bulb WILL fix a dark picture on this unit.
this projector does not have lcd's. it has a colorwheel and a light tunnel. the light tunnel has probably collapsed and needs to be replaced if you have distortion in the middle of the display. if it were to one side or the other or a the top or bottom it may have been adjustable. But wiith it being in the middle, I'd have to say you needed a new light tunnel.
Hmm my dad's old t.v. just cut out on him it took awile to turn on this my be the end of ur tv so this might be a power problem but older t.v. loose there colour on the screen my uncle had a like 10-15 year old t.v the screen was like green when it was light but when u turned of the light or closed the blind's it's picture was ok so try that.
OUCH! LARGE DARK SPOT IN CENTER IS NOT GOOD FOR PROJECTION TV. YOU BURNT THE TUBES. THE LOSS OF COLOR IS THE ROOT CAUSE SOUNDS LIKE A DEFLECTION CIRCUIT PROBLEM. THE TIMING FEEDBACK IS USED TO SYNC THE COLOR CIRCUIT. IF THE TUBES LIGHT WITHOUT DEFLECTION THEY BURN THE CENTER PHOSPHOR COATING INSIDE.
your light tunnel has collapsed and needs replacing. you can get the part and do it yourself, or you'll have to send it in to an infocus authorized service center. try av solutions in ny. they're pretty good.
The round blotch your seeing on the screen is the melting of an acrylic lens inside the light engine. Its a design flaw which unfortunately Infocus will not stand behind. To fix this problem requires opening the light engine and putting an equivalent lens in place. This task is very involved, but this problem is repairable and you need a glass smith to cut the right size lens from the original.
The more you play set the longer it will last, it sounds like you may have poor connections, cold solder joints try soldering around flyback transformer.
