20 Most Recent InFocus X1 Multimedia Projector Questions & Answers
Hi there.
How many hours had it done? The bulb may have expired and as a safety precaution the projector will not switch on, otherwise the bulb will explode causeing further damage.
Cheers
InFocus X1... | Answered on Nov 06, 2015
The light tunnel has collapsed. Google "infocus light tunnel." You can glue it, as I did, but it tends to break again. From what I have read nobody has a good fix and the manufacturer has ignored the problem which has alienated a lot of customers. They won't even sell a replacement tunnel. Good luck!
InFocus X1... | Answered on Oct 29, 2015
Assuming the power outlet and cable is OK the most likely problem is the power supply and needs to be replaced.
InFocus X1... | Answered on Apr 01, 2014
remove the lens rings using a flathead screwdriver and carefully pop them off. remove the 4 brass screws and the 4 silver screws from the bottom, and the 2 silver screws from the back. lift up the back panel from the bottom just a little. using a flathead screwdriver, pop open the 3 clips through the top vent of the rear panel. remove the rear panel. unplug the wire harness on the left and the small one on the right. lift up the top panel from the back a little bit and the front panel from the bottom. they will come off as one piece. be sure to blow out all of the dust with canned air. it's dry and there won't be any foreign particles in it. when you put everything back together, release the clip that attach the front to the top. put the top back on first, plug in the wire harnesses, then put on the front and rear panels. replace the screws. done.
InFocus X1... | Answered on Dec 28, 2012
hi,
do one thing. remove the fan from the projector. In the fan there will be a specification sticker. Remove the sicker. now u can see a hole in the center. its the bearing part of the fan. put one drop of oil in it. u can use any type of lubricating oil. rotate the fan leafs with finger for some time. after that re-stick the spec sticker. insert the fan in the projector.
ok
InFocus X1... | Answered on Jan 28, 2011
the connection between the main board and the light engine could be reseated to fix this. If that doesn't work the main board is bad or the dmd on the light engine is bad.
InFocus X1... | Answered on Aug 23, 2010
unfortunately there is nothing you can do but replace the panel or get a new projector.
InFocus X1... | Answered on Jun 25, 2010
I have seen this with a number of X1's and yes it will need to go into service and knowing what the cost of repairs was and the age of the x1 i would start looking for a new projector.
InFocus X1... | Answered on Jun 05, 2010
replace the light tunnel
InFocus X1... | Answered on May 19, 2010
sounds like your light tunnel is collasped or needs adjustment.
if it is over half your screen it is most likely the light tunnel under the colorwheel. If you have had it awhile the glue that holds the tunnel together deteriorates and they just fall apart. Or, the mirror inside the lens assembly may be knocked out of whack, but it's probably the tunnel.
InFocus X1... | Answered on May 18, 2010
go to menu,
select projection,change to front projection
InFocus X1... | Answered on May 08, 2010
InFocus X1 Multimedia Projector Logo
81 questions posted
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
martin hogg
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • InFocus Office Equipment & Supplies
Most Popular Question
get replacments lamp fan
  • Office Equipment & Supplies
