Hi there i bought a used weber silver grill it wont ignite it says start with a match to manual start it cant find the it says match hole
SOURCE: Weber grill
Can you tell if the gas is flowing? Its either dirty or perhaps your regulator got damaged. I'd check that out. Above all else, though, be careful!
SOURCE: Weber Silver B grill
I bet your grill gets no hotter than about 300 with the lid closed?
The tank has a built in safety feature. If a burner is left on when you open the valve on the tank, or turned on too soon immediately after opening the valve on the tank, the flow will be restricted. You need to turn all burners off, close the tank valve, disconnect the tank, reconnect the tank, open the tank valve, waqit a few seconds, open the burner valve and light. You'll get unrestricted flow and much better heat.
SOURCE: low/weak flame on Weber Genesis Silver B Grill.
hi my name is mark, could be one of two things the regulator on the propane tank try gently tapping on regulator it could be sticking, and make sure the vent on regulator does not have a spiders web . or the orifices to the burners are restricted. check regulator some are ajustable, some are not. hope that helps. thanks for your question.
SOURCE: Back burner won't light on my Weber Genesis Silver A Gas Grill
Only front burner lights (out of three) and it only has flame comming out of half of the tube.
SOURCE: How to replace ignition switch
where does the ignitor switch plug into ? genesis ....came unpluged
