I've got an AZKOYEN AZ04/M coffee machine which has a power knob with 4 positions. OFF, TEST, 1 & 2. It works fine and makes coffee perfectly well on either setting 1 or setting 2. I can't find the manual anywhere and wondered if anyone knows the difference. Using a power meter on the socket, it seems to use the same amount of watts on either setting. Is it a fast heat up or cleaning setting? 1 cup or two cup? Perhaps these type of settings are common to other brands of professional espresso machine. Any help gratefully received! Thanks.
On other machines with the position switches, 2 turns on the whole machine (elements heatup and groups work). Position 1 turns on only the groups but the machine never heats up. I have never worked on an azkoyen, but the test switch could be for the the board and the autofill circuits, instead of the technician turning the machine to 1 to test those functions, they provided a test position on the switch.
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop...
(More)
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop espresso maker?
My DCM485 seems to have stopped working. I can load water, but when I push the start button, nothing...
(More)
My DCM485 seems to have stopped working. I can load water, but when I push the start button, nothing happens. I was gone for two weeks, and machine was unplugged, so unsure what is going on?
