Re: Epson 1270 printer. New black ink cartridge in...
Try to reseat the cartridges. Then turn the printer off and on.
If you're still gonna get the same issue, call epson. I believe they replace defective cartridges.
The Epson printer won't recognize the ink cartridge when you have dried or empty ink, outdated printer drivers, ink cartridge not installed and much more. You can easily fix the Epson printer not recognize ink cartridge issue with simple steps.
·Remove and Reinstall the ink cartridge
·Check the ink cartridge
·Update printer Drivers
If your Epson printer blinks the Red or green lights, that means your printer has some other technical issue. You can fix the Epson printer lights blinking issue with these methods.
This happens with epson as it has a chip on the cartridge, which sometimes shows the cartridge empty even if there is some ink left on it. You can try this steps:-
1. With the printer turned on press the ink replace button, which will bring the print head to ink replacement position, pull out the cartridges one by one and cover the tip of the cartridge with some tape and shake the cartridges and reinsert it on the printer and press the ink replacement button once again, the printer will check the inks cartridges, if the inks is empty it will show the red light again, pressing the button once will bring the printer to ink replacement position with the cartridge to be replaced on the replacement position. you can also check on the printer software on the pc that which ink cartridge is emptied.
Hope this helps.
you better have your printer check by a qualified printer tech thus avoiding any further damage to the printer the printer head is the most likely problem to
If ink cartridge show red light for empty ink cartridge Just press the cartridge will come at standby those cartridge is empty ; just replace it. If not empty you want to change Press ink button ..... don't leave until your carriage unit not come at the replacement position First Black will come and next color will come and after pressing ink cartridge it initialized and it will be ready /
I realised that I had to replace both the ink cartridges even though I only wanted to replace the black for it to work. Once I replaced both the black and colour cartridge the red light went off. Thanks
Did you change from matte black to photo black? Or vice versa? If so you have to use the ink conversion kit that came with your printer and draw out the old ink and install the new black in cartridge. Try page 113 in your owners manual. I am having a similar problem but with the light cyan and it says "set ink cartridge".
I had the same problem with the light black and light magenta as well. It took trying only one new cartridge with the light magenta before it worked. The light black took 4 new cartridges before it worked. I had called the Epson support center on this problem and after going through suggestions they made that did not work, I told the guy I had another new cartridge on hand. He said to go ahead and try it. This time the printer worked. He took my name and address and said the other cartridges were faulty. Epson is sending me new replacement cartridges at no charge.
The Epson FAQ lists several techniques for resolving this problem.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=14374&infoType=Overview
There is also an animation on how to replace the ink cartridges.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=HowTo&oid=14374&prodoid=11473
