Not freezing
There are many reasons why is not working. 1.if the compressor is not running, Relay or overload burn, they are attached to the side of the compressor 2, thermostat may not be working. 3. if all of the part i mentioned are working fine your compressor may need to be replace.4 if the compressor runs but still don't get cool, there is a internal gas leak inside the freezer. The only way to find out theses issues, is by having the necessary tools and experience.
Hi kessy reddy, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
Can you hear the compressor (motor) running?
Are the indicator lamps lit?
Any sign of life at all?
motor runs gets a litte cold lights uniing on 240v slide switch is switche to low when sliding the control switch makes no diffrenece at all
Please forgive me, Did not understand the "lights uniing on 240v slide switch is switche to low when sliding the control switch makes no diffrenece at all" bit?
So the motor is running, the indicator lights works ok and the freezer does get a little cold but not the -18 or so degrees you would expect?
yes your are correct did a small mod used a thermistor 10k 25 c and jumpered ic pin 3 and 8 with r1 30k stll i dont think is colder enough should i replace the fan
Sorry, I don't think I can help you any more. If you are modifying circuit boards in the freezer your knowledge of this particular model is way above mine. Good luck
