GE Profile Spacemaker Stainless Steel Refrigerator Gmr04hascs Dorm/office Fridge Logo
A
Anonymous Posted on Feb 27, 2015
What temperature should my GE profile fridge be set at so that my food does not freeze
John
Level 3:
  • Master 794 Answers
  • Posted on Feb 27, 2015
 John
Master
Level 3:
Answers
794
Questions
Helped
290606
Points
3169
35 degrees F or 1.6 degrees C
Ge profile refrigerator temperature setting
Sounds like the damper controller is stuck due to obstruction or isn't working at all and needs replaced.
2answers
Freezer wont go below -9 degrees
This information does not mean anything to us if you didn't specify the model. In what temperature range a freezer works we knew thanks to the stars.
One star (-6 degrees centigrade) is perfect for making ice cubes and is sufficiently cold to keep food for three or four days.
** Two stars (-12 degrees centigrade) stores food for fifteen to twenty days.
*** Three stars (-18 degrees centigrade) will keep food safe for up to three months.
**** Four stars (below 18 degrees centigrade) means that the compartment provides the ideal conditions for freezing down fresh and pre-cooked foods.
Dado
What shld settings be as food is freezing in fridge it has side by side knobs saying colder mid less cold it is a westinghouse fan forced frost free freestyle unit
The settings are "relative". Someone with this fridge in Montana may need to run the same fridge with different settings than someone in Texas to get the same temperatures.
Many manufacturers recommend that the fresh food compartment should be 34 degrees F, and the freezer -10 to 0 degrees F. To set this properly, place a thermometer in the freezer (that can display temperatures as low as the desired temperature). Adjust the thermometer for the correct freezer temperature before going on to the fridge. A fully stocked freezer could take 12 hours or more for temperatures to stabilize after making changes to the thermostat. Once the -10 to 0 degree temperature has been achieved, set the fresh food compartment temperature.
Place a thermometer (that can display below freezing) in a 6 (or so) oz flexible plastic cup of water and place on a shelf in the fridge. A glass of water could break if the temperature gets below 32 degrees if the water turns to ice. The water acts as a buffer to rapidly changing temperatures when the door is opened to read the thermometer. If the fridge is "full", allow 24 hours for the temperature to stabilize before making changes.
If the fridge and freezer are empty, changes may be seen in just a few hours or less. Otherwise, wait the 12 / 24 hours for the freezer / fridge compartments.
I hope this helps and good luck!
Sep 06, 2011 • Freezers
1helpful
Freezer drops in temperature and food defrosts; freezer then re-starts and re-freezes food
Hi, The unit is sticking in defrost for too long...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 05, 2011 • GE Freezers
The frigde is turned dow but still freezing all
your cold temperature control is bad, not shutting the unit down when the temperature is correct. needs to be replaced.
The back of mt fridge is frozen. I've set the temperature between 4 - 5. If I put food near the back it freezes. What is the best thing to do?
Move items that are susceptible to freezing towards the front. The air circulates in from the back and anything set directly in the airstream will freeze.
Eric
Oct 14, 2009 • Freezers
1helpful
Candy cpca291ffk fridge freezer
This is due to the failure of the thermostat device..hence its not controlling the temperature..If you are good at electrical appliance repair i can tell u how to fix it...Otherwise i advice you give it for servicing...Let me know what you have choosen..
Oct 18, 2007 • Freezers
Top GE Freezers Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you a GE Freezer Expert? Answer questions, earn points and help others
