My son's 2nd generation ipod touch received water damage and now the touch screen does not work....how can I fix this..need it fixed for antother child
Hi tonyacompton..
If you ever find that you have to deal with a wet device, don't just abandon it.
Instead, try the following method to repair the water damage:
DO NOT TURN IT ON!
Take it apart as much as you can. Take out the battery, the memory card and whatever else can be easily disassembled. (Just make sure you can put it back together.)
Store the parts in an air-tight container covered with either dry rice, silica gel packets or kitty litter. These will absorb the moisture from your electronics device, leaving it water-free.
If no rice, gel packets or kitty litter are available, try using a vacuum to **** the water out.
DO NOT blow-dry the parts, it will only force the water farther in and cause more damage.
Free answer...Please take time to rate me.
