Question about O2 Samsung SGH-E250 Cellular Phone
Want to do a factory reset on my samsung e250
Posted by auberyo on
  • JATT BOY Sep 20, 2009
    i forget my phone password now what can i do??
SALMAN NASEER
    Genius:
  • 1,011 Answers
Here are all codes for E250,
enjoy and dont forget to rate it as it will fix the issue.
*#1111# ------------------ S/w Version
*#1234# ------------------ Dev.Version FW
*#2222# ------------------ H/w Version Rev
*#0206*8376263# ------ S/w Version ,Dev.Version FW,H/w Version Rev,time and Month and year flash *#0206*8378# ---------- Test Mode
*#4777*8665# ---------- GPRS Tool
*#0206*523# ------------ brightness of the display of 1-5
*#7465625# -------------- Interrogate - indication locks
*#0206*377# ------------ Error -- Table errors
*#0206*327# ------------ EEP(01/10)
*#0206*667# ------------ Debug mode
*#92782# ----------------- User agent (samsung-Sgh-G600/G600XEGH3)
*#232337# --------------- bluetooth addrnap uap lap
*#28837# ----------------- S/w Version BT and H/w Version BT
*#288378# --------------- Bluetooth Test
*#56658378# ------------ Look Test (Bomba code in a well-meaning words)
*#638738# --------------- Profiles Gprs- Inet settings (choice of various countries)
*#36245# ----------------- Test Mode (e-mail, mms, etc.)
*#0206*3768665# ------ DRM Tool (java, etc.)
*#777324# --------------- PPP TEST Menu
*#0673# ------------------ Mp3 Test Menu
*#0206*6366# ---------- Memo test
*#4378378# ------------- Gfs test
*#7378378# ------------- RESours Test
*#688# -------------------- Vod Test
*#64898378# ------------ NITZ test mode
*#898378# --------------- Timezone test mode
*#875108# --------------- FM Radio- speaker volume 1-10
*#52828378# ------------ Java Test Menu
*#73887# ----------------- Setup Wizard: (off/on)
*#2769737# -------------- Browser Test Menu
*2767*8451# ------------- Reset
*#738277# ---------------- Auto Profile Setting ( on/off)
*#0206*8376263# ------ S / w Version, Dev.Version FW, H / w Version Rev, time and Month and year flash
*#0206*8378# ----------- Audio Settings [menu (2) H / W test]*2767*688# = Unlocking Code
*#8999*8378# = All in one Code
*#4777*8665# = GPSR Tool
*#8999*523# = LCD Brightness
*#8999*3825523# = External Display
*#8999*377# = Errors
#*5737425# = JAVA Something{I choose 2 and it chrashed}
*#2255# = Call List
#*536961# = Java Status Code
#*536962# = Java Status Code
#*536963# = Java Status Code
#*53696# = Java Status Code
#*1200# = AFC DAC Val
#*1300# = IMEI
#*1400# = IMSI
#*2562# = ??? White for 15 secs than restarts.
#*2565# = Check Blocking
#*3353# = Check Code
#*3837# = ??? White for 15 secs than restarts.
#*3849# = ??? White for 15 secs than restarts.
#*3851# = ??? White for 15 secs than restarts.
#*3876# = ??? White for 15 secs than restarts.
#*7222# = Operation Typ (Class C GSM)
#*7224# = I Got !! ERROR !!
#*7252# = Oparation Typ (Class B GPRS)
#*7271# = Multi Slot (Class 1 GPRS)
#*7274# = Multi Slot (Class 4 GPRS)
#*7276# = Dunno
#*7337# = EEPROM Reset (Unlock and Resets Wap Settings)
#*2787# = CRTP ON/OFF
#*3737# = L1 Dbg data
#*5133# = L1 Dbg data
#*7288# = GPRS Attached
#*7287# = GPRS Detached
#*7666# = SrCell Data
#*7693# = Sleep Act/DeAct (Enable or Disable the Black screen after doing nothing for a while)
#*7284# = Class : B,C or GPRS
#*2256# = Calibration Info
#*2286# = Battery Data
#*2527# = GPRS Switching (set to: class 4, class 8, class 9 or class 10)
#*2679# = Copycat feature (Activate or Deactivate)
#*3940# = External loop test 9600 bps
#*4263# = Handsfree mode (Activate or Deactivate)
#*4700# = Half Rate (Activate or Deactivate)
#*7352# = BVMC Reg value
#*8462# = Sleeptime
#*2558# = Time ON
#*3370# = EFR (Activate or Deactivate)
#*3941# = External looptest 115200 bps
#*5176# = L1 Sleep
#*7462# = SIM phase
#*7983# = Voltage/Frequenci (Activate or Deactivate)
#*7986# = Voltage (Activate or Deactivate)
#*8466# = Old time
#*2255# = Call ???
#*5187# = L1C2G trace (Activate or Deactivate)
#*5376# = ??? White for 15 secs than restarts.
#*6837# = Official Software Version
#*7524# = KCGPRS
#*7562# = LOCI GPRS
#*7638# = RLC allways open ended TBF (Activate or Deactivate)
#*7632# = Sleep mode Debug
#*7673# = Sleep mode RESET
#*2337# = Permanent Registration Beep
#*2474# = ???
#*2834# = Audio Path
#*3270# = DCS support (Activate or Deactivate)
#*3282# = Data (Activate or Deactivate)
#*3476# = EGSM (Activate or Deactivate)
#*3676# = Flash volume formated
#*4760# = GSM (Activate or Deactivate)
#*4864# = Dunno doesn't work on newer versions
#*5171# = L1P1
#*5172# = L1P2
#*5173# = L1P3
#*7326# = Accessory (I got ********)
#*7683# = Sleep variable (
#*7762# = SMS Brearer CS (Activate or Deactivate)
#*8465# = Time in L1
#*9795# = wtls key
#*2252# = Current CAL
#*2836# = AVDDSS Management (Activate or Deactivate)
#*3877# = Dump of SPY trace
#*7728# = RSAV done# (Everything went to standart but nothing was deleted)
#*2677# = ARM State (None or Full Rate)
*#8999*636# = Have no clue what it is, i see 20 lines
*#9999# = Software version
*#8999*8376263# = HW ver, SW ver and Build Date
*#8888# = HW version
*#8377466# = Same HW/SW version thing
*#7465625# = Check the locks
*7465625*638*Code# = Enables Network lock
#7465625*638*Code# = Disables Network lock
*7465625*782*Code# = Enables Subset lock
#7465625*782*Code# = Disables Subset lock
*7465625*77*Code# = Enables SP lock
#7465625*77*Code# = Disables SP lock
*7465625*27*Code# = Enables CP lock
#7465625*27*Code# = Disables CP lock
*7465625*746*Code# = Enables SIM lock
#7465625*746*Code# = Disables SIM lock
*7465625*228# = Activa lock ON
#7465625*228# = Activa lock OFF
*7465625*28638# = Auto Network lock ON
#7465625*28638# = Auto Network lock OFF
*7465625*28782# = Auto subset lock ON
#7465625*28782# = Auto subset lock OFF
*7465625*2877# = Auto SP lock ON
#7465625*2877# = Auto SP lock OFF
*7465625*2827# = Auto CP lock ON
#7465625*2827# = Auto CP lock OFF
*7465625*28746# = Auto SIM lock ON
#7465625*28746# = Auto SIM lock OFF
*2767*3855# = E2P Full Reset
*2767*2878# = E2P Custom Reset
*2767*927# = E2P Wap Reset
*2767*226372# = E2P Camera Reset
#*6420# = MIC Off
#*6421# = MIC On
#*6422# = MIC Data
#*6428# = MIC Measurement
#*3230# = Trace enable and DCD disable
#*3231# = Trace disable and DCD enable
#*3232# = Current Mode
#7263867# = RAM Dump (On or Off)
*2767*49927# = Germany WAP Settings
*2767*44927# = UK WAP Settings
*2767*31927# = Netherlands WAP Settings
*2767*420927# = Czech WAP Settings
*2767*43927# = Austria WAP Settings
*2767*39927# = Italy WAP Settings
*2767*33927# = France WAP Settings
*2767*351927# = Portugal WAP Settings
*2767*34927# = Spain WAP Settings
*2767*46927# = Sweden WAP Settings
*2767*380927# = Ukraine WAP Settings
*2767*7927# = Russia WAP Settings
*2767*30927# = GREECE WAP Settings
*2767*73738927# = WAP Settings Reset
*2767*49667# = Germany MMS Settings
*2767*44667# = UK MMS Settings
*2767*31667# = Netherlands MMS Settings
*2767*420667# = Czech MMS Settings
*2767*43667# = Austria MMS Settings
*2767*39667# = Italy MMS Settings
*2767*33667# = France MMS Settings
*2767*351667# = Portugal MMS Settings
*2767*34667# = Spain MMS Settings
*2767*46667# = Sweden MMS Settings
*2767*380667# = Ukraine MMS Settings
*2767*7667#. = Russia MMS Settings
*2767*30667# = GREECE MMS Settings
*335# = Delete all MMS Messages
*663867# = Dump Mm file
#*536961# = WAPSAR enable / HTTP disable
#*536962# = WAPSAR disable / HTTP enable
#*536963# = Serial eable / Others disable
#*53696# = Java Download Mode
#*5663351# = Wap Model ID [Your Model]
#*5663352# = Wap Model ID [SEC-SGH***X/1.0]
#*566335# = Wap Model ID [SEC-SGH***X/1.0]
*2767*66335# = Check on which model it is
*2767*7100# = SEC-SGHS100/1.0
*2767*8200# = SEC-SGHV200/1.0
*2767*7300# = SEC-SGHS300/1.0
*2767*7650# = Nokia7650/1.0
*2767*2877368# = Reset WAP Model ID to standart
regards
Posted on Apr 08, 2009
fodorpavel
I need code zmrznut my mobile Samsung E250i
Posted on Mar 09, 2011
Dream
  • O2 Master
  • 6,120 Answers
Restore Deleted Data from Samsung
Here I'll introduce you Android ToolKit - Android data recovery to restore deleted data from Samsung, which has been widely accepted as the best recovery tool to recover deleted data from Samsung Android phone selectively. By using this tool, all deleted contacts, messages, call history, videos, photos, documents, WhatsApp messages, and more will be deeply scanned and recovered from your Android device. You are allowed to preview the data before recovery.
Additionally, this program enables to extract data from broken Android device, backup & restore Android on computer safely. Compatible with almost all Android models, such as, Samsung (Galaxy Note 9/8/5/4, Galaxy S10/S9/S8/S7/S6), HTC, Lenovo, Huawei, Google Pixel, LG, Sony, OPPO, OnePlus, ZTE, Xiaomi, etc,.
LEARN MORE
Android Data Recovery Software
How to recover lost video from Samsung Galaxy S8 S7 S6
How to recover deleted lost data from Samsung Galaxy S8 S7 S6 S5 S4
How to recover lost data from Samsung Galaxy Note 4 5 S7 S6
How to recover lost call history from Samsung Galaxy S9 S8 S7 S6 S5
Posted on May 30, 2019
Anna Santos
    New Friend:
Sgh-e251 stuck in its startup. How can I do to recover my phone?
Posted on Oct 30, 2013
2 Related Answers
Anonymous
SOURCE: i want to reset factory settings on my samsung
*2767*3855#...............jealan Cabardo
Posted on Jun 13, 2009
zine205
Challenges Man
  • 146 Answers
SOURCE: i want to reset my
just type this code *2767*2878# OR
*2767*3855 **
Posted on May 11, 2011
HOW TO retore factory setting in a SAMSUNG E250?
try
Home > Menu > Settings > Privacy > Factory Data Reset > Reset Phone > Erase Everything.
Jun 05, 2011 | Samsung Lands Phones
I forgot the phone lock password for my samsung E250 cell phone how do i reset it back to factory settings
if thats the case then u will need to flash your device with the samsung code from your computer or go to any samsung branch nearest to you for assistance and if u can log on with the code and u need a factory settings then you will go to the settings from the menu there u will find a factory settings and click on the reset it will go back to the initial stage without the code
Feb 07, 2011 | O2 Samsung SGH-E250 Cellular Phone
Virus removal in sgh e250i phone
my dear friend e250 dosent get infected by virus, it might be some software issue, you can try resetting by code, caution all your data , contacts, ringtones will be deleted.
you can go to settings and take option reset factory the code is 00000000 eight zeros.
or you can use this service code *2767*3855#.
check an comment
Dec 22, 2010 | O2 Samsung SGH-E250 Cellular Phone
I cannot make calls or receive calls on my Samsung-E250, THERE IS NO NETWORK AT ALL
does it say limited service? if so don't just do a normal factory settings, do a manufacturer reset, press this as if you were entering a PH.N0...*2767*3855#
Mar 01, 2010 | O2 Samsung SGH-E250 Cellular Phone
How can I reset my mobile phone factory settings
The easiest way to take care of this is to just take it back to where you bought it and they can do it for you. There is a special sequence of buttons and commands you must enter to completely reset it and the companies usually keep those a secret.
Sep 22, 2009 | O2 Samsung SGH-E250 Cellular Phone
Sansung E250
the default code is 0000-0000
May 20, 2008 | Samsung SGH-Z150 Cellular Phone
Samsung E250
factory restore should reset this the password is eight 0
Apr 28, 2008 | Samsung SGH-D500 Cellular Phone
Reset password on Samsung SGH-E250
*2767*3855# resets all locks xx hope it helps
Sep 06, 2007 | Lands Phones
O2 Samsung SGH-E250 Cellular Phone Logo
12,892 people viewed this question
Top O2 Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Jean Thiebaux
Are you an O2 Cell Phone Expert? Answer questions, earn points and help others
