I purchased these headphones from a local Target store yesterday and the left earbud worked fine directly after purchase but when I attempted to listen to music this morning no sound would come out of the left earbud. I tried the headphones on several devices and forms of media in case it was just splitting the sound oddly but to no avail
Maybe you should clean the headphone jack. If there is dust blocking one of the electric shocks, one side may not work. The best solution to check whether the problem is on earbuds or output device is change to another device. If it is the problem of the headphone jack, you can consider to contact manufacturer for a hardware repair. If it is the problem of your earbuds, you can change to a new one. Here is a blog including some best wireless earbuds recommendations. Hope it a help on making a decision: https://www.leawo.org/entips/best-tws-wireless-earbuds-1409.html?fixya=1409
Che k the end of ur headphone jack also check where its being put into possibly to rule out its not faulty headphones i sugest try them on something else then u can rule that out
SOURCE: Sony MDR-NC11 Left Earbud has no sound
They should come apart right where the metal meets the plastic, just below the buds themselves - be careful, one set like that I took apart were actually surface-mounted to the housing, there weren't any leads to repair...
SOURCE: The right earphone on my headphones stopped making
if you are techy or have a knowldge in connecting wire, then you can give a try to fix the right portion of your headphones. There was just a wire inside of your earphone which have been cut. For some instance maybe you had pull your headphones thats why the wire inside has been cut. If you can't repair then that's the time you'll need to buy.
all you can try is reworking the cable to the faulty side, common on all such deviced
