20 Most Recent Sony SY-ICF-C414 Clock Radio Questions & Answers
Plug in the unit.
First, the month and date appear, then the
year, and then the current Eastern Standard/
Daylight Time appears in the display.
Press
TIME ZONE
Area number "2" appears in the display.
If you live in the Eastern Time zone, you do
not need to adjust the area setting.
Area number
Time zone
Atlantic Standard/
Daylight Time
(default)
Eastern Standard/
Daylight Time
Central Standard/
Daylight Time
Mountain Standard/
Daylight Time
5
Pacific Standard/Daylight
Time
6
Yukon Standard/Daylight
Time
7
Hawaiian Standard/
Daylight Time
Press
TIME ZONE
repeatedly until the
desired number appears.
The display returns to the clock about 4
seconds after the operation is complete.
Note
During the shipment and your first use, a clock
error may occur. In this case, refer to "Setting the
clock and date" to set the correct time.
When daylight saving time
(summer time) begins
This unit employs Automatic Daylight Saving
Time/Summer Time adjustment. The DST
indicator appears in the display at the beginning
of the daylight saving time (summer time), and
disappears at the end of it.
Daylight saving time begins at: 2:00 AM on the
second Sunday of March.
Standard time begins at: 2:00 AM on the first
Sunday of November.
To cancel the automatic DST/summer
time adjustment and to set DST display
manually
The automatic DST/summer time adjustment can
be cancelled.
Press and hold
DST
for at least 3 seconds while
the clock is displayed.
A beep sounds, and "Aut
OFF" appears in the
display to show that the automatic DST/summer
time adjustment is cancelled. The display returns
to the clock.
Notes
Daylight Saving Time depends on the law in
each country/region, and your area may not use
it. In such a case, cancel the automatic DST/
summer time adjustment before using the set
and set the time manually as necessary.
To activate the automatic DST/summer time
adjustment again, press and hold
DST
for at
least 3 seconds. A beep sounds, and "Aut
On" appears in the display to show that the
automatic DST/summer time adjustment is
activated. The display returns to the clock.
To change the display to the daylight saving
time (summer time) manually, see "To change
the display to the daylight saving time (summer
time) indication."
Setting the clock and
date
To change the setting manually, follow the
procedure from step
Press
CLOCK
for at least 2 seconds.
You will hear a beep and the year will start to
flash in the display.
Press
or
until the correct year
Press
CLOCK
Repeat steps
and
to set the month,
day and time.
After setting the time, two short beeps sound
and the clock starts from 0 seconds.
Pressing and holding
or
changes the year,
month or day rapidly.
When setting the current time, time changes
rapidly by 1 minute-increments up to 10
minutes, and then by 10 minute-increments.
While setting the clock, you must perform each
step within 65 seconds, or the clock setting
mode will be cancelled.
To display the year and date
Press
SNOOZE/DATE/SLEEP OFF
once for the
date, and within about 3 seconds press it again for
the year.
The display shows the date or year for about 3
seconds and then changes back to the current
time.
If you connect the AC plug to an AC outlet while
this unit is powered from the backup power
source, the current date and time appears in the
following order (the same as when the unit is
powered on after a power interruption).
"month and date" (about 1 second)
"year"
(about 1 second)
"current time"
saving time (summer time) indication
Change the daylight saving time (summer time)
adjustment setting according to the following
procedures if you have cancelled the automatic
DST/summer time adjustment.
Press
DST
The DST indicator appears in the display and the
time indication changes to the daylight saving
time (summer time).
To deactivate the daylight saving time (summer
time) adjustment, press
DST
again.
Sony SY-ICF-C414... | Answered on Jan 04, 2018
Sarkari Result is providing the results of government Exams and admit card of the government exams. We provide the updates of the government exam results and admit cards. We provide the Updates of the government exams. We provide the admit card of the government exams and you can also know your result from this website.
Sony Audio... | Answered Yesterday
Hello Joanne, the Sony CDP-C225, is a 5 CD audio player
To listen to your Sony CDP-C225, on your Toshiba 46sl412u, you have to connect the LR audio output of the Sony to the LR ColorStream® HD / VIDEO audio input on the back panel of the Toshiba, then turn on the equipment, charge the CD on the Sony and you put in the Toshiba the Video input and there you can listen to the music of your Sony
I send you the links to download the manuals of Sony and Toshiba
I hope you can interconnect the equipment and enjoy the music
Greetings Franco Dosil
Hola Joanne, el Sony CDP-C225, es un reproductor de 5 CD de audio
Para escuchar tu Sony CDP-C225, en tu Toshiba 46sl412u, tienes que conectar la salida de audio L R del Sony a la entrada de audio L R ColorStream® HD/VIDEO en el panel posterior del Toshiba, luego prendes los equipos, cargas los CD en el Sony y pones en el Toshiba la entrada de V?deo y ah? puedes escuchar la m?sica de tu Sony
Te env?o los links para que descargues los manuales del Sony y del Toshiba
Espero que puedas interconectar los equipos y disfrutar de la m?sica
Saludos Franco Dosil
https://support.toshiba.com/support/modelHome?freeText=2941924
https://data2.manualslib.com/pdf2/25/2419/241856-sony/cdpc225.pdf?aca4bda68ee4e97a5d512bb41ffa4c33&take=binary
Sony Audio... | Answered 2 days ago
Use code search on your unidentified URC to find something that works. If a search through all codes stored in the URC fails, try a different one.
Sony Audio... | Answered on Jun 10, 2019
on this error read out - battery could be the problem is its battery operated - try hard wire to the wall outlet if u have a adaptor or maybe new batteries- of course the heads in the machine could be out of alignment- try another CD- do the easy steps first- if the walkman is real old, maybe its time for a new one if all other issues fail to solve problem -- also u could open machine up to see if a wire is burnt or has become loose. solder joints sometimes let go or a wire breaks
Sony Audio... | Answered on Jun 09, 2019
Hello Oliver, Question, the Sony sound equipment model, is the
STR-540 or the STR-HD540
Because of the STR-540, I can not find information to see the connection options you have to solve the problem you pose
I wait your answer
Hola Oliver, Pregunta, el modelo de equipo de sonido Sony, es el
STR-540 o el STR-HD540
Porque del STR-540, no logro encontrar informacion como para ver las opciones de conexion que tiene para poder resolver el problema que planteas
Espero tu respuesta
https://www.manualslib.com/manual/441025/Sony-Str-Dh540.html https://data2.manualslib.com/pdf4/99/9816/981588-sony/kdl48r530c.pdf?44a099fa3901575ad71a0683c529c045&take=binary
Sony Audio... | Answered on May 28, 2019
Sony SY-ICF-C414 Clock Radio Logo
2 questions posted
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
set time
  • Audio Players & Recorders
