Question about Bose in-ear headphones - Black with black/white cord
Left earbud problems
My left earbud just does not produce sound unless the jack is in an exact spot but that never stays
Posted by bmc55 on
Anonymous
Well, I had the same problem with the right earbud. Luckily I was under warranty with Target, so they told me to contact Bose. I did and they had me send in the headphones (to make sure I waas telling the truth) and about 2 weeks later I got my earbuds back. Their customer service is excellent, so that's what I would reccomend
Posted on Aug 20, 2009
  • Anonymous Aug 20, 2009
    If I was unclear in the below solution...They send you brand new earbuds stil in the packaging and everything. And you get to keep your rubber ear pieces from the broken pair.
wwlvictoria
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Bose Master
  • 1,001 Answers
Headphone is easy to pair to most Smart Phones and Bluetooth-enabled Tablet.
You can wear the earphone while you're running or working out, and do not have to stick your iPhone in pocket.
make you enjoy the exercise. Amazon com Bluetooth Headphone Charm sonic for Gym Runing Exercise Sports...
Posted on Dec 17, 2016
treeeee
    Master:
  • 519 Answers
Do you want to try bluetooth wireless earbud
Amazon com YELLWWORSE Bluetooth Headphones V4 1 Wireless Sports Stereo... ..................
Posted on Nov 28, 2016
The speakers no long produce sound after using the headphone jack,,disconnected jack , still no sound
When you plug in the headphones, the jack itself routes the signal away from the speakers. When you unplug the headphones, the jack has contacts that close again, routing signal to the speakers. If the jack contacts are dirty, they won't close correctly. I suspect were you to clean the contacts, you'd solve the problem.
Feb 25, 2015 | RCA Rt2760 Home Theater Receiver
The left earbud of my new headphones wont work
Che k the end of ur headphone jack also check where its being put into possibly to rule out its not faulty headphones i sugest try them on something else then u can rule that out
Oct 28, 2017 | Sony Audio Players & Recorders
My apple ipod, 8gb, 4th gen. has an audio jack issue. The earbud cord was yanked from the ipod while moving and since that time, the sound will only come out of the left side of any WORKING earbuds I try....
Hi jodisully,
sorry for my previous confusion, you can change the audio jack easily, purchase the audio jack from the below link -
http://www.kingipod.com/4g-ipod-parts.html
Please follow the below link to know how to replace them -
http://www.ipodhowtovideo.com/4thgen/4gheadphonereplacement.html
(jack cost is around 5 usd only, and there are complete help regrading replacement)
Please post comments for more information.........
Good luck!!
Thanks
Jan 06, 2010 | Audio Players & Recorders
The left earbud of my Bose in-ear headphones doesn't have sound
You probably need to replace the stereo plug on the end that goes into the jack. Most of them are molded on unfortunately but it can be done with a new jack and some soldering skills. There have been lots of people with the same problem on this site so there are already some good explanations of how to do this on here.
Aug 28, 2009 | Audio Players & Recorders
No sound in right earbud?
sounds like your 3.5mm jack (headphone jack) s broken. try getting a new one on ebay. if you are not confident opening your ipod, find a handy friend to do it for you
Aug 17, 2009 | Apple iPod MA446LL/A MP3 Player
Poor quality suddenly
you got a loose connection there...try to find the source of the problem - is it in the plug or the jack?
Aug 10, 2009 | V-Moda Vibe Earbuds Professional...
Left side quit working, not earbuds, i tried other sets
I had the same problem. the stereo mini jack connection to the circuit board of the mp3 player is broken or loose. I jiggled the jack around and the sound came back into both ears but that only worked for a little while and is annoying. Basically, unless you can re-solder the mini jack to the circuit board, or get someone to do it for you, your player is now just a flash drive.
Aug 08, 2009 | Mach Speed TRIO Onyx MP3 Player
Sony MDR-NC11 Left Earbud has no sound
They should come apart right where the metal meets the plastic, just below the buds themselves - be careful, one set like that I took apart were actually surface-mounted to the housing, there weren't any leads to repair...
May 27, 2009 | Sony MDR-NC11 Consumer Headphones
Skullcandy earbuds one earbud not working
It is likely that your right stereo channel has either been severed somehow or there is a severe short in one of the cables. What you can try to do to test this theory is first turn on your music. Then wiggle the cable at the very base of the right earbud. If nothing happens wiggle the cord right where it connects to the stereo jack. If still nothing happens run your fingers along the right earbud audio cable bending and twisting it. If at any point you hear music again then you likely have a short. If it is near the earbud then it is going to be difficult to fix since these earbudfs have a large gauard. If the short is at the stereo jack then the fix is simple. A standard 1/8" stereo jack can be purchased from any electronics or audio store. You can then fairly easily seperate teh old stereo jack and solder this new one in place. Search the internet for tutorials on how to do this if need be. Even if you do not get any kind of sound when wiggling it at the base of the jack this is the most likely culprit since this is where most of the stress on the headphones occur. Be wary though, if you do attempt a stereo jack repair you will void whatever kind of warranty your earbuds may have so check before you try. But, in teh end you may end up saving a 60-100 dollar set of earbuds for 5-8 dollars. Hope this helped.
Aug 13, 2008 | Skull Candy LINK Earbuds Consumer...
Bose  in-ear headphones - Black with black/white cord Logo
1,680 people viewed this question
Top Bose Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
