20 Most Recent Sony SRS-D4 2.1 Speaker System - Black Questions & Answers
Hello Graham, for what you say you have one or more control buttons of your Sony SA-PM65MD defective, this does not work properly the rest of the buttons
The correct repair would be to replace all the buttons
If you can't do it, consult a specialized technical service
I hope you can solve the problem
Greetings Franco Dosil
Hola Graham, por lo que comentas tienes uno o mas botones de control de tu Sony SA-PM65MD defectuosos, esto hace que no funcionen correctamente el resto de los botones
La reparaci?n correcta, seria reemplazar la totalidad de los botones
Si no puedes hacerlo, consulta con un servicio t?cnico especializado
Espero puedas resolver el Problema
Saludos Franco Dosil
Sony Audio... | Answered on Sep 16, 2019
Hi Andrew, what kind of speakers do you use?
If they are passive, they will not work, because your icf-sw55
It has headphone output and recording output
You must use powered speakers or connect it to an audio amplifier
Discuss what speakers you are using
Regards Franco Dosil
Hola Andrew, que tipo de altavoces utilizas?
Si son pasivos, no funcionaran, porque tu icf-sw55
tiene salida de auriculares y salida de grabaci?n
Debes usar parlantes potenciados o conectarlo a un amplificador de audio
Comenta que parlantes estas usando
https://www.manualslib.com/products/Sony-Icf-Sw55-2954809.html
https://www.manualslib.com/manual/991971/Sony-Icf-Sw55.html
Sony Audio... | Answered on Sep 12, 2019
Disc loader mechanism fault. Contact any service technician. The mechanism should be taken out from the set for repair, and this is a skilled work. If you wish to get some details; visit the site linked here. Pull up older posts. http://schematicscom.blogspot.com/
Hi Hoyt, clean the readers' lenses, with a cotton swab subtly soaked with a drop of isopropyl alcohol
If you use it with batteries or batteries, check that they are in good condition
Always test with original discs, this way you will know if the Laser reader still has the ability to work
If after these tests, you cannot read, consult a technical service specialized in Walkman
Discuss models of Sony players
Hola Hoyt, limpia las lentes de los lectores, con un isopo de algodon mojado sutilmente con una gota de alcohol isopropilico
Si lo usas con pilas o bateria, controla que se encuentren en buen estado
Siempre prueba con discos originales, de esta manera sabras si todavia el lector Laser tiene capacidad de trabajo
Si despues de estas pruebas, no llega a leer, consulta con un servicio tecnico especializado en Walkman
Comenta los modelos de los reproductores Sony
Sony Audio... | Answered on Sep 06, 2019
The replacement belt could be slipping but another area of concern would be a weak motor.
Sony Audio... | Answered on Aug 25, 2019
On off pressure air pressure switch not working , check for adjustment.
Sony Audio... | Answered on Aug 23, 2019
Hi Mark, check that the fiber optic cable is not damaged, has no breaks in its extension
replace and test with another cable, if the fault continues, check the audio input assignment in the Bar
I hope you can solve it
Hola Mark, controla que el cable de Fibra ?ptica, no se encuentre da?ado, que no tenga quiebres en su extensi?n
reemplaza y prueba con otro cable, si la falla continua, revisa en la Barra la asignaci?n de entrada de audio
Espero que lo puedas resolver
Sony Audio... | Answered on Aug 18, 2019
Hi Darlene, the batteries of your Sony headset, are housed inside the right speaker, you will have to remove the pad, you will find the speaker cover, you must remove the four screws and carefully remove the cover and there you will see the batteries , are from Nickel Hydrogen, Sony part number:
1-756-109-11 BATTERY, NICKEL HYDROGEN
replace batteries, do not dispose of them in the trash
then do the reverse process and you will have your headphones working again
for the provision of batteries, you should look in your area for a Sony parts site
I send you the link of the MDR-F975R service manual, which are similar
I hope you can solve the battery change
Hola Darlene, las bater?as de tu auricular Sony, est?n alojadas en el interior del parlante derecho, deber?s sacar la almohadilla, encontraras la tapa del parlante, debes retirar los cuatro tornillos y sacar con mucho cuidado la tapa y ahi te va a aparecer las bater?as, son de N?quel Hidr?geno, numero de parte Sony:
reemplaza las bater?as, no las deseches en la basura
luego haz el proceso inverso y tendr?s funcionando nuevamente tus auriculares
Por la provisi?n de bater?as, deber?s buscar en tu zona alg?n sitio Sony de repuestos
Te env?o el link del manual de servicio del modelo MDR-F975R, que son similares
Espero que puedas resolver el cambio de bater?as
https://www.manualslib.com/manual/948619/Sony-Mdr-Rf975r.html
Sony Audio... | Answered on Jul 31, 2019
Hi Betty, I send you the link to download the user manual of your ZS-PS50
I hope you can resolve your concern
Hola Betty, te envio el link para que descargues el manual de usuario de tu ZS-PS50
Espero que puedas resolver tu inquietud
https://www.appliancesonline.com.au/public/manuals/Sony-ZSPS50-Boombox-CD-Player-User-Manual.pdf
https://www.manualslib.com/manual/1333767/Sony-Zs-Ps50.html https://www.sony-latin.com/es/electronics/support/boomboxes-zs-series/zs-ps50/manuals
Sony Audio... | Answered on Jul 23, 2019
Sony SRS-D4 2.1 Speaker System - Black Logo
0 questions posted
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
sony sa pm65md only works remote may
  • Audio Players & Recorders
