The stove top works but the oven won't work. The digital clock is out.Should I have a repair man come out to replace the curcuit board or should I buy a new one? It is 4 years old.
? 4:44
https://www.youtube.com/watch?v=OmOocInxHOo
Jun 28, 2013 - Uploaded by ApplianceVideo.com
... symptoms: Clock and display does not work At: http://www.appliancevideo.com For ... and show you how to ...
? 3:42
https://www.youtube.com/watch?v=0RSnf4wfSZM
Oct 20, 2011 - Uploaded by PartSelect
Range/Stove/Oven Repair - Replacing the Clock Timer (Frigidaire Part .... My timer still works fine, but ...
Replace the clock .takes it out almost every time.most newer ovens the clock runs everything but your top burners .call repair clinic.com and order clock.(main control board.) Number is 1-866-822-0890 or 1-800-269-2609
bad sensor or bad computer board or clock assy.read out the sensor and find the tech sheet for your stove and it will tell you what the sensor should read out on,if the sensor is good then you have a bad computer board or clock assy.you can look up the error codes on the tech sheet too,look on the back of the stove,the papers are usually there on the back of the top console.F2
Oven temperature is too high 1. Look for welded relay contacts on bake or broil relays. If
this happens, replace oven control (also called clock or ERC). 2. For SELF
CLEAN models: check door lock operation. 3. Look for a high resistance
connection or any other cause of high resistance in the oven temperature sensor
circuit. Check sensor, sensor harness and sensor harness connection at sensor
and oven control. Replace sensor if found defective.
Remember:
Oven control (ERC) measures resistance of sensor circuit, not actual oven
temperature
ater spilled (4-5 cups) on the stove top running down into the stove control panel face (where you view oven temp, timer, etc). No water ever dripped into the oven or oven window. The stove top still works but the oven, warming drawer, clock are all non responsive after three days. No buttons on the control panel work at all. What repair is needed?
Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
Most electric range ovens are controlled by the electronic oven control (EOC). If your oven is not working and there is no display on the clock, more than likely you have a bad EOC. The board is not serviceable and has to be replaced. I hope this helps.
