2006 Honda accord dash lights are very low and looking for dimmer switch
You lost the operators guide, well, why not get one,
honda offers them.
here it is for free.
enjoy (coupe)
yes, RTM read the manual. its there, free at link below.
http://justgivemethedamnmanual.com/honda/honda-accord-coupe-owners-manuals/
SOURCE: dash lights
possibility of a dimmer switch malfunction, did you check all the fuses under the dash and also under the hood. check thuroughly because you might have missed one.
And where your dimmer switch is, us a stanely knife on the corner and it should pop out.. peice of cake, the dimmer has 2 wires in it so you can take a volts tester to see if it gets current when your head lights are on. Alos if it is getting current only on 1 side you can bypass it for another test by just running a wire from both points.
Does your other dash peices light up like your ac controlls and your clock?
if so it might be part of the dash cluster has just burnt out, bulb wise and 3-4 screws around the cluster and it pulls out also. All hondas are like legos and they come apart Very simpley.
If it isnt either of those, then you might have a bad MFS witch is shot for multi function switch and it is the lever that controlls your lights. Its expensive to replace though and is a hastle to remove from the steering coloum to test.
Get yourself a volts, oms tester and check the dimmer switch 1st.
if thats alright then test with the wire.
if thats alright then check the back lights behind your cluster for burtn out bulbs,
and if all that looks good your down to the fuses might just look good, and the MFS
hope that narrows it down for you
Good Luck!
SOURCE: 99 HONDA ACCORD BRAKE LIGHT (DASH) KEEPS COMING ON
Open the hood and look near the firewall on the drivers side. You will see the black rubber cap on a plastic resevoir. There is a switch that turns on when the fluid level gets low. This may be your issue.
Please remember to rate this solution.
SOURCE: 95 Honda Accord, fuse keeps blowing and no dash lights
sounds like a short
look at wires under dash
then look at te wires coming through the fire wall
check lighter too it might have a coin stuck in it as it will cause a short too
