DC25's cleaner head is engineered with a low profile to clean under the edges of low furniture. However for cleaning under very low furniture we'd recommend using the onboard hose, wand and tools as the vacuum itself is not engineered to lie flat to the floor.
If you'd like some advice from our experts on getting the best out of your machine, please give us a call directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Give me some advice on where is the best place to buy sectional sofas and what they should be? So that they are pleasant to the touch, I don't want to consider leather sofas.
Keep your upholstered furniture looking fresh by vacuuming it regularly
with the upholstery tool attached to your vacuum's hose. Prevent the
fabric from fading (or at least delay this) by keeping your furniture
out of direct sunlight -- close blinds, shades or curtains when the sun
shines most directly through windows closest to the upholstery. And
remove stains by blotting them with a dry cleaning solvent. Before
steam cleaning your upholstered furniture, read the piece's cleaning
code label to determine whether or not it is safe to do so. Then rent
or buy a steam cleaner (also called an extractor) and follow the
directions below.
Rent a steam cleaner or purchase one; buy steam cleaner solution.
Step 2
Vacuum
the upholstery on the furniture you wish to steam clean; use the
upholstery attachment to most effectively **** up loose debris.
Step 3
Test
the steam-cleaner solution on the upholstery in an inconspicuous place
to ensure the color won't be steamed out or drastically altered.
Step 4
Attempt
to remove any stains with a stain removal or dry cleaning solution.
Follow the directions that come with the product you choose for the
best results, and allow the stain remover to dry before you begin steam
cleaning.
Step 5
Remove cushions and, if necessary, arm covers.
Step 6
Gently apply the steaming water and cleaning solution in straight lines across the upholstery one section at a time.
Step 7
Use the cleaning extension on the steam cleaner to **** up as much water as possible. The dirt will come out with the water.
Step 8
Clean
one side each cushion (then allow it to dry) before cleaning the other
side. If the cushions are permanently attached to the furniture, clean
them last.
Step 9
Allow the furniture to dry completely before repeating the steam-cleaning process or replacing the cushions.
