Question about Danby DWC283BLS Wine Cooler
Danby wine cooler not cooling - dwc283BLS - Danby DWC283BLS Wine Cooler
Posted by neofathering on
  • 1 more comment
  • neofathering Jun 05, 2011
    I didn't mean to report your response as an abuse, just wanted to continue the conversation - sorry!
  • Anonymous Mar 11, 2014
    brake line diagram for 1997 oldsmobile cuttlass
  • Anonymous Mar 12, 2014
    td1 1.9 jetta
Jeffy
    New Friend:
Take a look on amazon for parts... here: Amazon com Danby wine cooler parts. I hope this helped.
Posted on Dec 10, 2014
Lance Hill
    Genius:
  • 1,739 Answers
This product is now retired however was able to locate your manual here:
http://www.danby.ca/cms/uploads/products/en_manual/DWC283BLS_%28web%29.pdf
Verify you have power to the unit?
Have you provided proper spacing of 5" between the unit and any adjacent wall? Note these are free- standing units and are not meant to be built in.
Make sure it is not located adjacent a heat source or in direct sunlight.
Check to make sure you have set the temperature controls correctly. See page 4 of the manual. Note if the power is interrupted your settings are erased and the cooler will default to the preset temperatures.
if you have power and the temperature settigns are correct ther eis likely an issue with the compressor and it may need to be serviced.
To find your nearest service dealer go to the following site:
http://www.danby.com/language_sel.php?ref=%2Flocator.php%3Ftype%3Dservice
Select your county and then click on Service in the horizontal menu bar.
Posted on Jun 05, 2011
Marlon Deza
  • 670 Answers
Please make sure that the cooler is receiving power. check for any signs like If you can hear the fridge thud when you turn the knob on or if theres a light on just to make sure that you have power.
If the power is okay the second thing you have to check is the condenser, see if it is showing some sign of life it should hum or you should feel it vibrate. If it's not then that means that is the reason why it's not cooling. Some refer to it as the motor but it's the round thing inside the fridge. The condenser is responsible for distributing the freon around the cooler so if it's gone bad then the fridge will not start to cool.
However, if the condenser shows a sign of life you may want to check the freon level. Freon is a CFC that gives the coldness that your fridge has, Without it then it wont work. Have a local technician check the freon level and see it it needs to be refilled.
1 Related Answer
Dennis Boxerman
  • 1300 Answers
SOURCE: we have a danby dwc283bls wine cooler that no
that's always a possibility but not always the case. The thermostat may not be cycling correctly or set wrong. The condenser could be dirty or if there is a fan, it may not be running. Freeze ups can also cause an "Out of temp." condition. Check it out.
Posted on Apr 15, 2010
F230073 p c card
try there http://www.searspartsdirect.com/partsdirect/part-model/Danby-Parts/Wine-beverage-cooler-Parts/Model-DWC283BLS/3055/0169000/50031952/00001?blt=06&prst=0&shdMod=DWC283BLS
Dec 16, 2013 | Danby DWC283BLS Wine Cooler
Need parts diagram for dwc283bls-1
http://www.searspartsdirect.com/partsdirect/part-model/Danby-Parts/Wine-beverage-cooler-Parts/Model-DWC283BLS/3055/0169000?pathTaken=&prst=0&shdMod=DWC283BLS
Dec 25, 2012 | Danby DWC283BLS Wine Cooler
Danby DWC166BLSRH is not cooling. Fan is on and a clicking sound comes on, and compressor is very hot but will not cool.
I have the same problem. Mine probably needs refrigerant so it's a safe bet that yours does too. I'm going to order some and fix it, then update.
Aug 19, 2012 | Danby DWC283BLS Wine Cooler
Danby DWC283BLS has condensation inside the unit.
wine coolers have no means of draining the condensate inside them,use silica gel(1/2 pint)to keep the inside dry(remember to dry it out when condensate happens again)
Jul 16, 2010 | Danby DWC283BLS Wine Cooler
Danby wine cooler compresser not running and is hot
The compressor needs to be tested to see if it's operational. This normally needs to be done by a service tec.
Aug 21, 2009 | Danby DWC283BLS Wine Cooler
E4 message
Disconnect the power cord from the wall outlet and wait 30 minutes before pluging back in. This should clear all settings on the cooler.
http://www.danby.ca/cms/uploads/products/en_manual/DWC283BLS.pdf
Aug 07, 2009 | Danby DWC283BLS Wine Cooler
Non-stop cooling fan or compressor
I have only found Danby as a source for these parts, 419-425-8627
May 20, 2008 | Danby DWC283BLS Wine Cooler
Danby DWC283BLS Wine Cooler Logo
8,632 people viewed this question
Top Danby Furniture Experts
Dennis Boxerman
jdthefixer
jasbo
jasbo
Are you a Danby Furniture Expert? Answer questions, earn points and help others
