Question about Ekornes Stressless Recliner Chair
How do I fix a swivel mechanism that is not turning? With the chair upside down I can barely turn the ring by hand; i put a few drops of oil and it now turns more easily; but when I"m sitting in the
How do I fix a swivel mechanism that is not turning? With the chair upside down I can barely turn the ring by hand; i put a few drops of oil and it now turns more easily; but when I"m sitting in the chair, it still won't swivel.
Posted by Kathleen Leuba on
jfhinton45
  • 3,506 Answers
Probably need a new one but try more oil first
Posted on Oct 19, 2014
Scott Graham
    New Friend:
Hi Kathleen. My pivoting was squeaky and tight as well. My solution was to flip the Stressless and literally pull the base off the seat base's pivot point -- the two detach from each other (they're simply pressure fit together). As it turns out, my pin coming down from the seat base was pitted with mild surface rust. A bit of metal cleaner (I used CLR Metal), some ultra-fine steel wool, and elbow grease cleaned it to almost new in about ten minutes. After that, I greased (white grease or titanium grease) the pin and the inside of the base's pivot before forcing the two parts back together. It spins like a dream now, and is silent.
Posted on Dec 16, 2015
  • Carrie B
    Carrie B Feb 27, 2020
    Thank you for this! I have an Ekornes Stressless recliner with a signature base (the metal and wood type that tilts and spins), so the base doesn’t come off without a tool. So I just flipped my chair upside down, resting the seat on my sofa, and applied some grease directly into the pivot area. Then I spun the base around in both directions, rocked it back and forth and all around, before flipping the chair back onto the floor. It’s silent and spins like a dream now, so thank you! It’s a new chair, less than a year old, and it started squeaking and creaking at the pivot earlier this winter. You saved the day!
Our chairs will not swivel properly. What can we do?
SUSAN, WHAT KIND-OF CHAIRS?? TURN CHAIR UP-SIDE-DOWN SPRAY WD-40 INTO BEARING AREA THAT SWIVELLS ,SHOULD FREE-UP AND WORK LIKE NEW, YOU HAVE TO MAINTAIN THESE CHAIRS EVERY SO OFTEN! THANKS
Jan 24, 2016 | Ekornes Stressless Recliner Chair Personal...
Hand wheel will only turn a quarter turn and needle barely moves even though smaller hand wheel is tight.
If this is an older mechanical machine (ie, NOT computerized), sounds like it has not been cleaned and oiled in quite some time and the old oil has solidified. DO THIS ONLY IF IT IS A MECHANICAL MACHINE! Consult your owner's manual, get some good quality sewing machine oil (not your grandmother's oil tin, 3-in-1 oil, WD-40, or cooking oil). Start with 1-2 drops of oil each place as directed by the manual. Gently hand-rotate the wheel (do not try to run the motor until the internal mechanics of the machine are moving freely!). To speed things up, direct heated air from a handheld hairdryer into the interior mechanism. You may need to repeat the process every day for a few days before things loosen.
The machine should be oiled every 8 hours of constant sewing, every time a new bobbin is installed, before its use after it has not been used recently, or at least every 6 months if it is in storage.
Sep 16, 2015 | Sewing Machines
How do I fix an error e6?
Start by trying to turn the wheel with the bobbin and the auto-thread cassette removed. Look inside to see if there is any thread caught anywhere both in the bobbin area and also in the complicated mechanism where the auto-thread cassette fits.
  • If it is still stiff, remove the needle plate, which also holds-down the cover over the bobbin carrier. (You may need to use a coin and a pair of pliers to undo the 2 screws as there is very limited vertical clearance at this point)
  • Remove the bobbin carrier, noting which way it fits. Thread and fluff can build up in this area.
  • Thread might have become wound round under the rotating component into which the bobbin carrier fits.
  • Put one drop of oil in the edge of the large screw in the centre of the rotating component and turn the wheel a few times. Put another drop of oil in the same place and continue to turn the wheel.
  • Look carefully with a small flashlight into the case and see if there is any fluff or thread bits caught in the feed dogs mechanism.
  • Put one drop of oil onto any joint between moving parts that you can see.
Now, if there is no improvement and you cannot see any threads caught, you need to see if there is anything wrapped round the bevel gear drive under the bobbin carrier rotating mechanism.
If you go to "How to fix Brother's CS-8060 bobbin auto winder to work?" thread on this forum there is a description of how to separate the 2 halves of the case. (I apologize for omitting to say about Large +Screw #6, located in the top of the case where the Auto-Thread cassette fits)
  • Splitting the case enables you to have a good look around under the mechanisms and check for any thread or fluff. Put one drop of oil on any moving joint.
  • Rotate the wheel, being careful to keep your fingers out of the way as you do so. Take careful note of the area below the bobbin mechanism, where there is a bevel gear that turns the drive through 90 degrees.
  • There is also an eccentric part that moves the feed dogs mechanism. Check there is nothing clogging-up this bit. You can use Lithium-based grease very sparingly to lube the cams and plastic/nylon components
  • Put one drop of oil onto the needle-shaft, above where it slides through the mounting. Turn the wheel a few times and put just one more drop of oil.
  • Look at the crank mechanism that drives the needle-shaft and apply one drop of oil on any moving joint or component.
  • While you are in this area check that all the bits that move do so freely, especially the little joints of the auto-thread.
  • Have a good look around the area of the bobbin winder, up by the wheel. - Has the bobbin winder drive rubber gone gooey? Is there anything caught up there?
Hopefully you may find what is causing the stiffness. It is not really likely that one of the shaft bearings is tight but you can put a little oil each side of the bearing and continue to turn the wheel to see if this frees-up any.
Take care to wipe any excess oil off, particularly where it might get on anything you sew.
Don't get oil on the drive belt and don't blow any fluff up into the motor area or, especially, the speed-sensor disk (which is a black thing with fine slots.
Assemble the components carefully. You might take a few cell-phone pictures to help remember how things go.
Feb 19, 2015 | Brother CS-80
Shaft does not rotate motor workink
My Bamix stopped working--no shaft movement and loud motor noise (think disuse caused motor lubricant to thicken). Propped it upside down and put drops of quality machine oil at seam where narrow blade shaft enters larger shaft (in center of curved guard). Probably not necessary, but added a few drops where large shaft enters handle. Oil slowly seeps in. Attached a blade to manually turn for oil distribution. Did this periodically over several hrs. Turned on low speed and it gradually returned to full speed capacity.
Oct 25, 2013 | Bamix De Luxe Hand Mixer
I have a jazzy 1107 power wheel chair the back wheels are leaned outward i dont think the back wheels should be leaned outward i think this is what is causing me not be able to be able to turn properly....
Have some one check out that the section has not become loose or broken. IF the wheel rubbers are damaged then you will have trouble regardless of what you do. I consider it paramount that the chair is in top condition for your needs. Have the manufacturer's service agent fix it for you.
Sep 22, 2013 | Health & Beauty
How to remove swivel base from lazy boy recliner
This individual wants to remove the base from a recliner, not a tv. Take the back off the chair. Turn it upside down and remove four bolts, two front, two back that bolt the base to the chair on arms. Contact lazy boy first. You can get a new base from them that is stationary and put it in place of the swivel. I have same problem. Swivel is constantly turning and drives me crazy.
Jul 04, 2012 | Televison & Video
The front wheel on the mamas and papas sport 03 is wobbling. how do i fix it?
On the footrest is a plastic oval motif.
Flip the push chair over and pop the two lugs out and remove.
You will see a nut.
Use a 17mm ring spanner to tighten this up so the wheel doesn't swivel easily by hand (the weight of the push chair will still swivel it properly).
Bingo! No more wobbles.
Press the grey clip back over the nut.
I know this works because I did mine this afternoon!!
Mar 27, 2011 | Baby Trend Expedition LE Jogger
Where does the oil go?
To oil machine.....Remove the bobbin case.Snap the two retaining arms outwards.Remove the hook race cover (circular ring ) and the hook ( half semi circular) and clean with a soft cloth.Lubricate right hand side wall ( 1-2 drops of oil) turn hand wheel a few times until the hook race is in the left position...replace hook..replace hook race cover ( smooth end to the bottom) and snap back the two hook retaining arms and insert bobbin case and bobbin.
Jan 06, 2008 | Singer 1116 Mechanical Sewing Machine
Ekornes Stressless Recliner Chair Logo
8,018 people viewed this question
Top Ekornes Furniture Experts
Tom Chichester
ray gallant
Are you an Ekornes Furniture Expert? Answer questions, earn points and help others
