Sharp Notevision PG-C45X Multimedia Projector Logo
s
stephen Posted on Nov 04, 2013
I have a sharp notevision DLP xr10x projector. Two red lights, one is the lamp, the other standby/power. I changed the lamp but nothing changed. I can't even turn the thing on. Any ideas?
John Reilly
Level 1:
  • Contributor 37 Answers
  • Posted on Nov 04, 2013
John Reilly
Contributor
Level 1:
Answers
37
Questions
0
Helped
26177
Points
68
Hi Stephen,
Do you hear any fans starting when you turn on the projector? Try unplugging and then plugging in the projector. Make sure that the lamp door is secured as the projector will not start if it is loose. You should also reset the timer for your projector. The manual can be found on the site of www.allprojectorlamps.com.
My Sharp Projector xr10x will not come on, two LED solid red lights are displaying, bulb was recently replaced, was working fiine until we turned it off and turned it back on Please help!
The fault seems related to the lamp but it will be good to revisit the replacement of the lamp, check the lens cover section , the lamp cover as there are safety micro switches that need to be active to start the lamp. Also the filter must be cleaned. Check the power supply , check the connectors and fuse. If none of these rectify then the fault can be within the power supply or processor board.
The "lamp" light keeps blinking red. Does this
The lamp life becomes 0%, when used
for approximately 4,000 hours with "Eco
Mode" or when used for approximately
2,000 hours with "Standard Mode" (see
page 43).
When the remaining lamp life becomes
5% or less, " " (yellow) will be displayed
on the screen. When the percentage becomes
0%, " " will change to " " (red),
the lamp will automatically turn off and
then the projector will automatically enter
the standby mode. At this time, the
lamp indicator will illuminate in red.
If you try to turn on the projector a fourth
time without replacing the lamp, the projector
will not turn on.
If you require the manual to help with changing the bulb, send me an email to [email protected] Put SHARP PG-B10S in the subject line. I will send it to you right away. Lawrence Brown
I have a Sharp XR-10X-XL projector, i have replaced the bulb but it still will not go on. The Stand by light and the bulb light are both on constant red, I have checked both the heat sensor and the fuse on...
Reset the lamp timer.
1,Connect the power cord.
2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
3helpful
Unlock Sharp XR-10X-L Notevision Proj. says keylock function on
According to pg. 45 in the owner's manual, you turn Keylock function ON by holding down the ENTER key on the projector for about 5 seconds while the projector is being turned on.
To take the Keylock off-- Hold down the ENTER key on the projector for about 5 seconds. If the projector is in standby mode, you can release the keylock by holding down ENTER and STANDBY/ON keys simultaneously for about 5 seconds.
LCD projector shuts off durning use
u have not mentioned how long u have been using this projector. either the lamp life is low or the circuitry protecting the lamp temperature is defective or even the air intake of the fan is inadequate, a filter is fitted for air flow if this is clogged or blocked, lamp temp will rise and unit shuts down. if lamp indicator is yellow or red it is time to change the lamp. if it is red - lamp is totally out, if u turn on the unit four times without replacing lamp, the unit simply wont turn on. one other possibility is power cable and power connections. check power cable too.
I got a free sharp notevision PG-m20x. I plug it
if you don't hear a high-pitched whir, the colorwheel needs replacing. if you do hear it, the lamp may need replacing. if the lamp is new, there is a power supply problem.
2answers
Sharp projector xr10xl standby light flashing and lamp light on what is wrong?
if it's blinking green, nothing is wrong. it's just cooling. if it's blinking red and the lamp is off, the lamp door is open.
Sharp notevision PG-C45X will not turn on
possible blown lamp I think that is what the flashing red light means check manual
Sharp Notevision PG A10X
check the power supply heard issues with this system like that but was all related to the power supply
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
