I replaced busted developers and after 20k copies the copy went light even on darker density.
SOURCE: EP 5000 copie very light
did you run F-8 ? and make sure T/S and CHARGE are clean optic .
? is it happening when you manual darken density
''check your drum,and drum count
hope that helps
SOURCE: smearing wont go away
Yes most likely it is a fixing unit issue where the toner is not being melted to the paper properly. Usually there is pressure tabs on each side of the unit that can be released to remove jams, if one is up or broken it can be the cause esp if the smudges are only on one side. If not the fixing then could be drum blade bad as well. All in all you will probably need a tech.
Thanks,
TankMurdock
