Deh-1200mp no sound on tuner or cd
SOURCE: HOW TO AJUST THE CLOCK ON PIONEER CAR CD MODEL
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/370967683DEHP2900MPOperationManual1027.pdf
hi, if you click on the above link it will take you to your user manual for you model.
to adjust the clock it is on page 23 of section 7.
i hope that has solved your problem and please dont forget to rate my solution.
cheers
SOURCE: How can I set the clock on the Pioneer DEH-1200MP
1 Press SRC/OFF and hold until the unit turns off . 2 Press SRC/OFF and hold until the clock appears in the display. 3 Press F (function) to select the initial setting. After selecting, perform the following procedures to set the initial setting. 1 Press < or > to select the segment of the clock display you wish to set Hour -Minute 2 Press ^ or v to put the clock right.
SOURCE: Installed Pioneer DEH-1200MP, won't turn
What type of vehicle did you install this into? I can get you the wiring information if necessary. Make sure you are measuring 12V on your yellow (constant) power wire and 12V on your red (accessory) wire as well. Be sure to have a good ground as well. If these wires check out ok, check that the fuse (10amp below the radio harnesses plug) is good. Beyond this, you may have a bad unit. Hope this was helpful.
