If your roter settings have a place to "disable SMI Firewall", try that, my wii wouldn't conect to mine until i did that, othwise try it with no key and see if it will conect.
that is dependent on the wireless network you are connecting to. it is not a universal psp setting. you will need to check with the owner of that wireless network.
This type of error message appear when we are trying to connect to the wireless network. For Windows(xp) perform the following steps:- a)click on start menu and then go to control panel and then open network connections from there. b)Under network connections an option for wireless connection exist , right click on that option and then click on properties. c)Under wireless network connection properties there are three tabs general , wireless network and advanced. d)Left click on wireless network tab and check the box which says use windows to configure my wireless setting's and click OK at the bottom. e)Then , Right click again on wireless network connection and click properties and then again click on wireless network tab. f)At the bottom of the wireless network tab you will have preferred networks and in that small box yo will have list of networks and therefore delete all of them from there including the one you are trying to connect to. g)On the right hand side of preferred networks you will have ADD click on that option and enter the details of your network manually. SSID(name of the network) Network Authentication:-Open if the security is WEP else WPA-Personal. Encryption:-WEP for wep security TKIP/AES for WPA-PSK. Network key/Confirm network key:-is the wep key or wpa-psk password. Untick the box at the bottom that says the key is provided to me automatically. Click OK at the bottom and close the properties window. h)Then , Right click again on wireless network connection and then left click on view available wireless network. i)List of available networks will be there , select the network you use and try connecting to it , it will get connected automatically.
Take note all the wireless settings of the router first. Now go to the printer and Press Menu/Settings, look for wireless setup wizard. It should find the network, highlight it and connect. If it asks you for the network key, type your wireless network key. It only allows WPA-Personal(TKIP) and WEP. If you have WPA2 or AES, it will not connect
ssid is service set identifier usually sniffer software will find them. the wep wirless encription protocall is a key number usually found on a sticker on the bottom of the wirless modem, router .
To connect your modem to a wirless router. Then make sure when you set up the wireless router that you remember the settings (mainly the password) and what kind of security you set, WAP, WEP AES or TKTP. Also make sure the wirless connector is enabled on your PSP (basically a switch on top of your hand held system).
