SOURCE: GE top freezer refrigerator automatic ice cube
If it is leaking water in the freezer it will more than likely freeze amongst the ice cubes causing a block of ice.
It is more than likely leaking at the rear of the unit, near the valve or fill tube for the ice, this will run up the rear wall of the unit.
SOURCE: GE S/S Refrigerator model GSS20IEBWW auger not turning
Take a hair dryer and heat the auger drive gear. These will sometimes get moisture on them and freeze up.
Turn the refrigerator off first. Then remove the ice bin. The "U" shaped drive will be in the back.
After you have heated it thoroughly, try to move the gear manually. Resume power and try it again.
Good Afternoon friend, I appreciate your post!
Based off what you have described the door on your Frigidaire refrigerator is stuck and will not open. It sounds like you may have condensation on your gasket and it has frozen the door shut. The best thing to do is disconnect power from the refrigerator for four to six hours and that should break up any ice holding the door closed. I hope this is helpful information. -Matt
