Question edited for clarity, MAKER.
Question moved to Model Category.
Your fridge freezer has three fans.
The compressor evaporator fan cuts in and out as required to maintain temperature.
The fridge evaporator circulation fan runs to maintain an even temperature. It stops when to open the door and resumes when you close it and stops when the set temperature is reached as long as the compressor isn't running. If the compressor is running, the fan normally runs to prevent icing which happens slowly.
The freezer also has a fan, and that runs pretty much all the time unless target temperature is met and the compressor is not running. This fan runs when you open the door to stop the moist air from the room freezing on contact to the 0'F, -18'C evaporator fins. The fan keeps the air moving to deposit less frost.
It sounds like your is running normally except for the noise. Trace the noise and find it. The compressor fan has a Shark Paper fibre board cover and these often distort over time and touch the fan blades. That is the common cause. The less common cause is the internal fans pinging off built up ice that should have been removed during the defrost cycle.
When frost builds up on the little flapper at the top of the door above the ice maker it can get stuck. It tells the ice maker to keep making ice. Try cleaning the mechanism of frost and make sure it operates freely.
Open the freezer door. Pull the ice bin forward about 3 inches. Push the ice bin to the rear of the freezer until it seats and locks in place. Then try to dispense cubes. The ice bin can become dislodged from its locked position and the crushed ice solenoid activates automatically.
switch off machine. open doors an manually defrost.clean any filters/drain holes(wire is not heated,pull/push to clean pipe)dry as best you can.switch on again.it is best to manually defrost any unit every 6 months and if temp edjustable adjust to -20c for optimum economy.water to icemaker is not important on 601f but is on some others.be carefull
This will be caused by your fan inside the freezer. (The fan turns off when you open the door). Either the fan motor is bad or there is ice built up and the blades are hitting it. Good luck
Older icemakers have a bar that drops from above your ice bin; once the bin is full the bar is raised and trips turning the ice maker off so that it won't dump. If your's is this style, try manually pushing the free end of the bar upward so that it locks in the upward position. Newer ice makers with the ice bin in the door have a small panel that moves to the open position when the door opens and closes when the door closes. Mine also includes an optical sensor that is visible when this panel is in the closed position. Try placing a non-clear tape over the optical sensor (don't know if that will work or not but worth a shot). If effective in stopping the ice flow then call a repairman. If none of this works, turn off the water supply coming out of the wall to your freezer.
Sounds like you may have a couple of problems here. The frost build up could be from a bad door seal. Moist air can be drawn in and collect on the inside. As for the water temp, it sounds like the water line connected to the refrigerator could be tapped off a hot water line. It needs to be connected to a potible cold water line.
the water that is frozen in the fill tube could have come from the old water valve that you replaced ,you got to get the ice out, the easiest way ,though not the fastest ,is to unplug fridge for 24 hrs . and leave the doors open to let it defrost, the plug back up and hopefully in 5 or 6 hrs you'll have ice
It's not too difficult to remove the ice maker. A few screws and the unit will unplug from the fridge. Then you can see why the bar is not turning it off. If it's really broken, check pcappliance.com for parts or a replacement unit. Meanwhile the fridge can keep on working, and you can use trays to make ice.
