Yesterday I had problems finalising the DVD which eventually i did - then the girls upset because the DVD only recorder about half of the film. Tried recording it cagain this morning and the same thing happend... what am I doing wrong. The recording was for 108 mins. The DVD was a 2 hours disc. Copying from sky planner.
SOURCE: Won't recognise DVD Ram and non-finalised discs from own recordings.
Usually, the U11 error code in a Panasonic DVD player indicates an optical problem. You could of course try doing a cleaning using a CD cleaner normally readily from computer parts stores. Alternately, you can open the unit up and do a manual cleaning with soft bristle brush and/or cotton buds. Other than that, it could be indicative of a weakening laser eye which of course would require parts replacement.
Hope this be of initial help/idea. Pls post back how things turned up or should you
need additional information.
Good luck and kind regards.
Thank you for using FixYa..
SOURCE: Panasonic DVD player won't finalize
You can try a dvd+r disc. Borrow one before buying a stack of them.
The other thing is that you may not have enough free space left to burn the finalization track; 7 1/2 hours is a lot of recordings.
Give the +R disc a try even though it says it can't use them in your documentation, a lot of users report it works anyway.
Please don't forget to rate all of our solutions here on the board. Thanks.
Regards,
Worldvet
SOURCE: DVD recording problems
I have the same unit with the same exact problem. I ended up taking it in for repair and it's now working perfectly. I paid $100 for the repair. I dropped the unit off and picked it up myself. I think $30 additional is charged for shipping and handling in US.
PANASONIC CAMERA & DIGITAL SERVICE CENTER
1590 Touhy Ave
Elk Grove, IL 60007-5319
EMAIL [email protected]
888-439-2676
Part Number
RFKNEH75VP
Description
RAM/DIGITAL PCB MODULE
SOURCE: Panasonic DMR-ES10 DVD Recorder- does not read discs
this unit has an optical-eye, not recording heads. opening the drawer then unplugging unit will expose the eye. never look into the eye when unit has power. this x-ray can and will burn your owh eyes lens&retina. good luck. clean with 90% isopropyl alcohol and q-tip. mch
SOURCE: pansonic e 85h won't play recorded disc or
Chris you were right on with the cleaning I paid $50.00 for the lens cleaning from a certified Panasonic technician and now works like brand new I have invested a total of $200 for the power supply and lens/laser cleaning but I got the unit as a gift, minor probs with unit but great dvd recorder thanks!!!
Still a bit lost on this one - can anyone help me???
