My DVD player (LG RH1777 DVD Recorder) is no longer recognising DVD RW's despite recording movies...
(More)
My DVD player (LG RH1777 DVD Recorder) is no longer recognising DVD RW's despite recording movies from the machine to the DVD.
My dvd/hdd seems to have stopped receiving digital signal, wont auto tune, not picking up any...
(More)
My dvd/hdd seems to have stopped receiving digital signal, wont auto tune, not picking up any channels. Turn it on, it says hdd check, then comes up black screen. attempts to auto tune dont work. tried initializing to factory setting, no change. all cables plugged in. still receiving analog signal into tv via the dvd/hdd. Any ideas why?
lg hdd dvd recorder rh7521w is not able to read the disc. it gives unknown disc error for all the...
(More)
LG HDD DVD recorder RH7521W is not able to read the disc. It gives unknown disc error for all the discs. I tried disc cleaning cd also.
When you get no disk error, that is usually because of a problem with the
optical laser lens that is dirty, faulty or opaque, and will...
written by ginko
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down...
written by xmarine2847
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for the...
written by stoneheaded
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then...
written by MateusDIY
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems...
1)just open the player 2)remove the rubber belt connecting the dc motor 3)you
can open the disc tray now 4)if there are any dust particles or...
written by dileep007
It is always suggested that you use or buy a cd or dvd cleaner with it's cleaning solution, but I have discovered something that works just as well if...
written by BobbyR1234
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
