Dell 1470 (W9284) 802.11a/g/b Wireless Adapter Logo
Posted on Sep 20, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My laptop cannot connect to my local network (LAN)
My wireless card is Dell TrueMobile 1150 Series Wireless LAN Mini PCI Card.when i connect my laptop that i ve already added to my wireless network (workgroup),it keep telling me that wireless connection unavailable.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 19, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2608
Points
I cannot connect my laptop to my office LAN network, RJ-45 connector is to big for my port. what can i do?
A
Anonymous
SHOW WITH ICONS IT IS VERY EASY TO USER
Anonymous
Level 3:
President:
  • Master 2,961 Answers
  • Posted on Sep 21, 2007
Anonymous
Master
Level 3:
President:
Answers
2961
Questions
Helped
1638466
Points
8444
Assuming you initially set up the router using the wired lan adapter and lead, enabled DHCP in the settings. First stand right next to your router; Dells wireless is a little tempremental, go to control panel and in there should be Dell wireless monitor, open this up refresh it and see if it finds any wireless networks, if so try to connect. Dissable your wired network lan adapter. Go to the properties of your wireless card and on the TCP/IP line click properties again and ensure that obtain an ip address automatically is selected, press ok and restart the pc.
1 Related Answer
Anonymous
  • 6966 Answers
  • Posted on Sep 20, 2007
SOURCE: my wireless card
Hi, Sometimes the built-in Windows Wireless Configuration Utility fouls up. You may have to install and use the Client Manager Application for the TrueMobile 1150 Wireless Network Card. This is better explained at Hope this be of some help/idea. Pls post back how things turn up or should you need further information. Good luck and kind regards.
I bought a DELL optiplex 745-small form in Japan a couple of years back (Service Tag is HXXR8BX)and always used the pc with a LAN cable. Now I was tranferred to the netherlands and the house I live has a...
Below you will find 2 options to add wireless connectivity to your desktop.
A. USB Wireless LAN
http://accessories.us.dell.com/sna/category.aspx?c=us&l=en&s=dhs&cs=19&category_id=6638&nf=44907%7e0%7e598274&sort=-ratingaverage&~ck=anav
This is the easiest solution to add a wireless connection. Simply connect the USB adapter, install the software it comes with and connect to the wifi signal, once configured.
B. PCI/PCI-e Hardware Wireless LAN
http://accessories.us.dell.com/sna/category.aspx?c=us&l=en&s=dhs&cs=19&category_id=5821&nf=44907~0~598274&sort=price&~ck=anav
Adding a PCi/PCI-e expansion card requires opening your computer and manually installing the card, then installing the driver/software and configuring the wireless access. These cards typically offer faster speeds and stronger radios to communicate with wifi signals better.
NOTE: There are 2 types of wireless cards in the second link: PCI/PCI-e and Half-Card/Mini-Card. Half/Mini-Card adapters are for laptops only - they will not work on desktop computers!
Both USB or PCI/PCI-e offer excellent solutions to getting wireless access from your desktop. Furthermore, since it can be purchased through Dell.com, they can ship anywhere worldwide, so delivery to the Netherlands should not be a problem.
If you have any questions, you can always contact Dell's Customer Support by telephone and be sure to give them your service tag number, that will ensure that you get only the parts that match your desktop.
My truemobile wireless pc card will not connect using a wep key. Other devices connect with no problem. and it works when the key is not required. any ideas?
make sure you are putting in the correct wep key 0 zeros in computer language has a slash going through them as opposed to an o like in open...
Dell TrueMobile 1150 won't connect to secured wireless acct.
well! some wireless adapter`s are not capable of connecting to higher security so that`s why for that it`s recommended you use WEP security instead of WPA.
1helpful
Wireless lan networking for toshiba satellite 1900
Not enough info per problem description. Not all 1900 series laptops have wireless cards installed, and not all 1900 series laptops are ready to handle wireless cards, either. Need to know what model your computer is, what wireless card you're using, ... C'mon. Let's have it...
TrueMobile won't connect to my network
Over the past few months I have seem more of this issue. I am beginning to think that there may be Microsoft updates that could be conflicting with the wireless network adapter config. But this is only a speculation.
In the mean time, you may have a faulty wireless card. If the unit is under warranty, have Dell replace it. If not, you could disable the internal one and purchase a Linksys Wireless G or N USB adapter from Staples....just to rule it out.
GB Plus -
2answers
Dell TrueMobile 1180 802.11b/g Wireless Adapter driver for win2k
Did you buy this unit from dell, or snatch it from a dell machine?
http://www.support.dell.com
You may have to use your imagination, such as picking a laptop model that may have come with that card...
Wireless signal degredation
Disable and renable wireless card, even try unistalling the wireless card and reinstall it. update driver for wireless card. then if those fail, put pc next to router if signal still bad then card needs replaced. If your ISP didnt have you power off the router for 30 sec then do so.
2answers
COMPAQ EVO N400C WIRELESS CONNECTION PROBLEM
Is the truemobile your using a PCMCIA card you slide into a slot or is it a Mini-PCI card that is inside the laptop?
My wireless card is Dell TrueMobile 1150 Series Wireless LAN Mini PCI Card.when i connect my laptop that i ve already added to my wireless network (workgroup),it keep telling me that wireless connection...
3answers
Compact Flash 802.11b card?
just a guse but the batery looks to have enouth mA to run a CF 802.11b card and an sd blue touth card i think if you will be connected to a network or a wifi connection i would invest the money in the 3400MAH insted of the 1440MAH.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
