Dell TrueMobile 1180 802.11b Wireless Adapter Logo
Posted on Mar 13, 2009
TrueMobile won't connect to my network
I installed a TrueMobile 1180 Mini PCI wireless card in my Dell Latitude C810. My network shows up but the card will not connect to it. I'm set up with a linksys wireless router.
  • um56 Mar 13, 2009
    I got it, thanks, my router was set to G only, I reset it to mixed and it hooked roght up.
  • Anonymous May 11, 2010
    Did you reboot the router?
    Are you using WEP / WPA / WPA2 or some other form of encryption?
    Are you filtering by MAC address?
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Mar 20, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
772
Points
Over the past few months I have seem more of this issue. I am beginning to think that there may be Microsoft updates that could be conflicting with the wireless network adapter config. But this is only a speculation.
In the mean time, you may have a faulty wireless card. If the unit is under warranty, have Dell replace it. If not, you could disable the internal one and purchase a Linksys Wireless G or N USB adapter from Staples....just to rule it out.
GB Plus -
How to install mini card?
open slot underneath the laptop, is has a slot where it fits only in one way and has 2 antennas which you cant place wrong
My truemobile wireless pc card will not connect using a wep key. Other devices connect with no problem. and it works when the key is not required. any ideas?
make sure you are putting in the correct wep key 0 zeros in computer language has a slash going through them as opposed to an o like in open...
1helpful
I do not know as to establish a card.
There is nothing better than a Dell Laptop. Connect it run the driver software in the Laptop or you can also check any PCwhich is eqquiped to read memory card(this feature is common in Laptop PC's)......sodeep
2answers
Dell TrueMobile 1180 802.11b/g Wireless Adapter driver for win2k
Did you buy this unit from dell, or snatch it from a dell machine?
http://www.support.dell.com
You may have to use your imagination, such as picking a laptop model that may have come with that card...
2answers
WIRELESS CARD FOR LAPTOP
Hi
Your did not provide any info on which card you have or wish to install; USB, PC Card, or internal mini PCI card.
For mini PCI cards, first you have to open up the D600 laptop and install the Hardware (ensure to connect the antenna cables) then power-up and install the software (drivers and utility).
For USB and PC Cards, follow the device manufacture's recommended steps. Generally, for USB devices, the software (drivers and utility) needs to installed first before the hardware is connected.
If you have successfully installed the hardware and software (driver/utility) you can scan, choose and connect to an available wireless access point or wireless ad-hoc setup. This can be done through the wireless manufacture's utility or from Windows Wireless Zero Configuration utility. If you use the manafucature's utility, Windows Wireless Zero Configuration utility will not work; will not scan or list available wireless network.
Check "Dell Connect To A Wireless Network" article
http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&docid=338826
Mike
Dell axim x5 1180 truemobile wireless issues
Only WEP is supported------- also download the rom patch for this card off of the Dell site.
My wireless card is Dell TrueMobile 1150 Series Wireless LAN Mini PCI Card.when i connect my laptop that i ve already added to my wireless network (workgroup),it keep telling me that wireless connection...
Hi, Sometimes the built-in Windows Wireless Configuration Utility fouls up. You may have to install and use the Client Manager Application for the TrueMobile 1150 Wireless Network Card. This is better explained at Hope this be of some help/idea. Pls post back how things turn up or should you need further information. Good luck and kind regards.
3answers
My laptop cannot connect to my local network (LAN)
Assuming you initially set up the router using the wired lan adapter and lead, enabled DHCP in the settings. First stand right next to your router; Dells wireless is a little tempremental, go to control panel and in there should be Dell wireless monitor, open this up refresh it and see if it finds any wireless networks, if so try to connect. Dissable your wired network lan adapter. Go to the properties of your wireless card and on the TCP/IP line click properties again and ensure that obtain an ip address automatically is selected, press ok and restart the pc.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
