Computers & Internet Logo
EMMANUEL JAMES Posted on Sep 13, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Locked by bios pasward
My laptop is del and the latitute is c600/500 the problem i have is that i gave it to computer engineer to install me some applications, when he returnd the laptop back to me, i tried to power it on and it was asking me to enter pasward before it can boot. i called the engineer and explained every thing to him he toled that he dosen't no the pasward which meance that he can not solve the problem. the important thing is that vital document of Fight Against Aids Club are inside the laptop and i am being asked to present the document in three days time. so please help me out. i will be graetfull if a solution is given to me. thanks Emmanuel James.
Arnold G
Level 2:
Champion:
  • Expert 208 Answers
  • Posted on Nov 03, 2007
Arnold G
Expert
Level 2:
Champion:
Answers
208
Questions
0
Helped
123069
Points
334
If you call dell support they can verify he name address to the service tag and they can unlock it.
1helpful
How do I get it to go into bios when pressing f2 doesn't work?
Per the internet site, it depends upon the model of laptop. Here are some examples:
Laptops - Access Bios Settings Key
Issue
The most common Access Bios key is the "DEL" button or "F2". This depends on the laptop model, however, and can be confusing if you do not know which key to press.
Solution
Here is a list of laptop models and brands with the keyboard commands / key for accessing the BIOS Setup:
Acer: F1, F2, CTRL+ALT+ESC
ARI: CTRL+ALT+ESC, CTRL+ALT+DEL
AST: CTRL+ALT+ESC, CTRL+ALT+DEL
Compaq 8700: F10
CompUSA: DEL
Cybermax: ESC
Dell Laptops:
Dell 400: F3, F1
Dell 4400: F12
Dell Dimension: F2 or DEL
Dell Inspiron: F2
Dell Latitude: Fn+F1 (while booted)
Dell Latitude: F2 (on boot)
Dell Optiplex: DEL
Dell Optiplex: F2
Dell Precision: F2
eMachine: F2
Gateway 2000 1440: F1
Gateway 2000 Solo: F2
HP (Hewlett-Packard): F1, F2 (Laptop, ESC)
IBM: F1
E-pro Laptop: F2
IBM PS/2: CTRL+ALT+INS after CTRL+ALT+DEL
IBM Thinkpad (newer) Windows: Programs-Thinkpad CFG.
Micron: F1, F2, or DEL
Packard Bell: F1, F2, Del
Seanix: DEL
Sony VAIO: F2
Sony VAIO: F3
Tiger: DEL
Toshiba 335 CDS: ESC
Toshiba Protege: ESC
Toshiba Satellite 205 CDS: F1
Toshiba Tecra: ESC then F1 or F2
Toshiba Notebook [Newer models]:
  • Turn on the computer by holding down the power button while pressing the ESC key
    • The machine will beep, then display:
    • Check System, then press [F1] key.
  • Release the ESC key
  • Press the F1 key
Laptops Access Bios Settings Key
How to Enter Bios for MSI A6400 Laptop?
Press Del while the Press DEL to enter SETUP message displays on screen after powering on the computer. SETUP, in this case, is the BIOS.
3helpful
NO SE PUEDE INICIAR EL CARGADO DEL PROGRAMAS PORQUE TE PIDE PASSW
Remueva la bateria recargable, la bateria del BIOS y el power cable por 10 minutos. Esto borra el password del BIOS. Re-instale todo y trate de nuevo
2answers
Installing XP on a vista pre-installed laptop
your harddisk is not detected in bios.reconnect your harddisk power cable and sata or ide cable again.then check in bios harddisk is detect or not.
u cna enter in bios with "del" key when u power up ther computer prerss "del" or F2 keyh to enter in bios.
Blue scree, or system crash
This link should help you a lot. The problem is an unmountable boot volume.
http://www.techtips4u.com/kb/sw/SW00014.htm
Please let me know if this helps you out.
ABOUT BIOS SETUP DEFAULT PASWARD ACER 5573Z ASPIRE
There is no default password.The default is that there is no password set. If someone set a password it must be generated by a keygen based on your service tag or config numbers by Acer tech support. If you have forgotten, lost or never had one do not try removing the RTC battery or bother looking for non-existent jumpers as those only apply to desktop computers. The reason for this security is obvious. Steve
Pasward compaq harddrive pls guide it open and chang bard hard
To reset the BIOS password you must take out the BIOS battery on the motherboard of the computer.
On most desktops this is not a hard thing. Simply take off the side of the case, then take out the quarter sized battery on the motherboard, wait 60 seconds then reinstall.
On a laptop the same thing must be done but I must recommend you take it to a local technition as this is not an easy thing to do if you have never opened up your laptop.
Dell Latitude
ok, well, first of all, very very wrong category. You have a Dell Latitude notebook computer, not a Creative Zen Vision:M
you need to specify what screen you are able to go to. It could be that the BIOS master password has been set, in which case you need to take out the battery, unplug the laptop, and remove the backup battery (not sure if you are able to attempt this - i recommend letting a professional take apart a laptop as it is very difficult and time-consuming) to reset the BIOS. Can you hit F1, Del, or F12 while the computer is running the POST checks? This will get you into the BIOS and should allow you to remove any hard drive passwords or other security measures put in place by a previous owner.
Let me know how this works so I can assist you further.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
