20 Most Recent MPC Computers TransPort X1000 Notebook Questions & Answers
There is a problem with the internal wiring and if you have never repaired a laptop I don't suggest you start. Take it to a computer service center and they can fix it for you.
If you need further help, reach me via phone at https://www.6ya.com/expert/scott_843b43f7ebebd3f5
MPC Computers... | Answered on May 25, 2014
This often happens due to lack of correct drivers.You should check drivers from your manufacturer,and also check the condition of your wi-fi adaptor by using the device manager.
MPC Computers... | Answered on Apr 10, 2014
the best way to remove a bios password is to have the bios reset by a program called "winternals" this can be done by any pc repair shop
MPC Computers... | Answered on Oct 09, 2013
You can remove or change the Window's User or administrator's password and privileges. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
MPC Computers... | Answered on Mar 15, 2013
FIRST, WHY DO YOU WANT TO? Altering the BIOS is like taking a stroll in a minefield, one wrong step and........ That said, Is your computer running OK? Is there some issue you are trying to resolve? If you are asking for a "how to" , I assume you have never done it before. That's not a "pond you want to jump in", without checking how "deep the water is". I would advise you to rethink, and rethink the rethink. Have you looked on the laptop Makers website for a BIOS flash? Only use the laptop manufacturers website for BIOS updates/flash.
MPC Computers... | Answered on Nov 30, 2012
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
MPC Computers... | Answered on Apr 25, 2012
TRY http://www.mpcdrivers.com/servicemanuals.html
Having had a look around, MPC don't seem to have Win7 drivers available on their web sites.
This site does however list the XP drivers and the modules they're designed for.
http://www.mpcdrivers.com/apps/filelist7374.html
Theres a possible link and loads of info here in respect to your audio driver
http://pcsupport.about.com/od/driverssupport/tp/windows-7-drivers.01.htm
and here's a site which may have your wireless lan driver
http://download.cnet.com/Actiontec-802-11a-b-Wireless-LAN-Adapter/3000-2112_4-83486.html
MPC Computers... | Answered on Jan 25, 2012
If you visit this website:
http://support.dell.com/support/edocs/systems/latd520/en/index.htm
There are download links for both the User's Manual and the Service Guide for your model laptop. You can either download the guides or you can view them in your browser.
I hope this solution helps, and have a great day!
MPC Computers... | Answered on Nov 14, 2011
Dear Sir,
To remove password in your BIOS
1. Turn off your PC ang remove power cable
2. Open your PC Casing and find the CMOS battery
3. Remove CMOS Battery Located in your Motherboard
4. Most Bios Battery is CR2032 Lithium Battery
5. After removing battery Short circuit the Positive (+) and Negative (-) pin in your bios terminals using a metallic screw or any metal to connect both terminal.
6. Put back the CMOS battery to its original location.
7. Turn on your pc and press F2 or delete depending on your Motherboard BIOS key.
8. Check if you can enter the BIOS settings.
Hope this will help,
Markus
MPC Computers... | Answered on Apr 27, 2011
Take out the battery, hook up power striaght to the LP, Open up LP if this works then time to replace the batteries if not call or take it to the repair shop.
MPC Computers... | Answered on Apr 17, 2011
To reset the BIOS password read my instructions from this link.
MPC Computers... | Answered on Mar 19, 2011
MPC Computers TransPort X1000 Notebook Logo
61 questions posted
Top MPC Computers Computers & Internet Experts
Thomas F. Schneider
Joaquim Martins
Are you a MPC Computers Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • MPC Computers Computers & Internet
Most Popular Question
remove password from
  • Computers & Internet
