Toshiba SD-1200 DVD Player Logo
A
Anonymous Posted on Aug 18, 2013
After hello it says "disc error" - Toshiba SD-1200 DVD Player
If uncorrectable error(e32) disc can be run properly in PC or not
Hello Sanjeev
Disc will not run when there is error, every amount of data will be running and it is needed. Even dust will cause error, so you need to clean the dust and if the disc was scratch you need to find or buy another disc.
Best Regards
Neciforo Llanto
Error occured during loading operation 80010514
Hello jesus_its_sp
This error means that the PS3 is unable to read the disc.
Does this error occur with other games? Has this game worked before?
The first thing you should try is cleaning the disc. Do this using a clean, dry cloth. Start from the centre of the disc and clean outwards.
Check for scratches. If the disc is damaged, you´ll need to purchase another disc.
If the problem persists, you may have a hardware problem.
Hope this helps. Good luck
ajblaj
I keep getting wrong disc error on my Daenyk DVD player and do not understand why I have played these DVDs on it prior and no Problem
The reason the player keeps giving you wrong disc error is because the player is not reading the disc.
the reason is either the lens is dirty or weak.
To test if the lens is dirty, try to clean the lens with a lens cleaner and test the player DVD disc.
To fix it if the lens is weak, open the player with the appropriate screwdriver, open the disc tray, and replace the lens with a new lens, test it with a DVD disc.
Take care
Error couldnt read disc played disc 1 now wont read disc
hello have you tried a disc cleaner or the disc it's self may have deep scratch
regards
shaun
Unknown disk error when putting disk in player.
hello,
when the disc player shows unknown disc error, it simply implies that the lens of the player is weak and cannot read the disc.
the solution is for you to try to clean the lens with a lens cleaner or better still replace the lens.
take care
Wont read discs
Hello frnd,
Please explain your problem completely. like, when u insert disc, what error you get. Does your player show any error or just eject the disc.
Djajay
[email protected]
1helpful
Inserted disc reading "No Disc"
Hello Brian,
It looks like you have a bad lens assembly. That explains the "No Disc" error. Just get the lens assembly replaced and it will be back to normal.
Md350 disc error
Well, I solved it...cleaned the lens, and it's now working fine...
Bad Disc Errors
are they disks you burnt?
Disc error
when i press play on my dvd/cd player it says error
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
