Describe your zenith dvd player does not start Problem- when we put a dvd in, it won't start...
(More)
Describe your zenith dvd player does not start Problem- when we put a dvd in, it won't start automatically playing. It just says "loading" and then the display screen goes blank. It won't let you push play. This happens for every dvd we put in except for one. It worked fine 12 hours ago.
Is there any way to play a different regional code on the Zenith DVB412? I have a DVD from England...
(More)
Is there any way to play a different regional code on the Zenith DVB412? I have a DVD from England that I am trying to play. I know the 412 can play region 1 and all, anyway to change it to play other regions? I was told that there is a way to do it, but I can't figure it out. Thanks for the help!
The dvd player powers off after a few minutes when disc is not playing or no disc in in player. I...
(More)
The dvd player powers off after a few minutes when disc is not playing or no disc in in player. I need the dvd player to stay on when not in use.
volume is low when playing dvd's. Is it possible to program the zenith dvb410 remote to use the dvd...
(More)
volume is low when playing dvd's. Is it possible to program the zenith dvb410 remote to use the dvd volume buttons?
Our little Coby under-cabinet widescreen TV, which has been working for months up until later today,...
(More)
Our little Coby under-cabinet widescreen TV, which has been working for months up until later today, now just shows a "No signal" message on the screen. Nothing has been moved or changed, and we verified that the cable was still screwed in. We have DISH satellite and the Coby is one of two on the same receiver; the other TV receives just fine. Again, the Coby TV has been working, this is just all of a sudden.
We too have a problem with the "zoom" function on our TV. while it kind of works, the...
(More)
We too have a problem with the "zoom" function on our TV. while it kind of works, the display for the 2x of 4x zoom remains on the screen. It's a Sharp TV (flat screen, HDTV) and a Phillips DVD recorder. ?? Thanks for any information.
When you get no disk error, that is usually because of a problem with the
optical laser lens that is dirty, faulty or opaque, and will...
written by ginko
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down...
written by xmarine2847
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for the...
written by stoneheaded
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then...
written by MateusDIY
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems...
1)just open the player 2)remove the rubber belt connecting the dc motor 3)you
can open the disc tray now 4)if there are any dust particles or...
written by dileep007
It is always suggested that you use or buy a cd or dvd cleaner with it's cleaning solution, but I have discovered something that works just as well if...
written by BobbyR1234
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
