Hello, friend! I also meet this error about my cell phone, I get many help from this forum, and also bought many DIY repair tools from china supplier , and vipprogrammer help me fix this error. maybe you can try it.or contact ther WhatsApp:+ 8615986801289
Link: http://www.vipprogrammer.com.
They've solved my cell phone problem and I hope it will help you with your mobile phone trouble.
SOURCE: Uniden 5.8GHz can't turn ringer on
You should be able to go to the handset and do that. Hit the button above the caller id until you can hear it.
SOURCE: how do you turn ringer on and off on a uniden
hello. To turn the ringer off on that phone you need to get into the menu. The way you get into the menu is press and hold the menu/cid button for 2 seconds. Then press the arrow down button until you highlight the ringer volume. once the ringer volume is highlighted, press the select/channel button. that will rotate you through the 3 available volume levels. High, low and off. as you are pressing the select/channel button the handset sounds a sample of the volume level. when you hear the volume level you want simply press end and that will store your volume to the off position. to turn it back on, just repeat the above steps but select the proper volume level you want and then hit end. I hope this helps.. Don;t forget to rate me. thanks !
SOURCE: How do I turn off the ringer on my Uniden exi8560
Press cid/menu button and hold for 2 seconds. Press the down arrow buttton to choose RING VOL. Press the select/channel button to choose one of the three volume levels: high low, and off. Press the END button to end.
SOURCE: I have a Uniden phone
Please let us know the complete model number of the phone so that we can provide you with the relevant manual.
The model number should be like, for example, EXAI8580, TRU5885 or similar.
Please reply with the details. Thanks for using FixYa.
SOURCE: I have a Uniden 5.8, Model TRU9280-2 and have 2
You can download the manual at
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/TRU9280-2om.pdf
