20 Most Recent
Uniden DXA15588-2 Twin Cordless Phone Questions & Answers
Our phone rings only twice
With the phone in standby mode, press the menu/clock key three times.
You hear "Ring time" and the current ring time, and it is displayed on the main base. Then you hear the guidance for setting the ring time.
Press the volume/select-up-down until the desired setting appears.
Press the set key.
Full instructions are in the "Setting the Ring Time" section of the manual (page 36 in my copy). If you need a manual, you can download a copy at
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DXAI5588-2om.pdf
3/3/2013 7:14:49 PM •
Uniden...
Answered
on Mar 03, 2013
How do i get my
You can download a copy of the manual at
The remote operation instructions begin on page 46.
You can reset your PIN# by following the instructions on page 35.
9/19/2011 9:28:54 PM •
Uniden...
Answered
on Sep 19, 2011
Battery life is very short.
One source for about 15USD is at
http://www.batteriesplus.com/products/549-0/5275-Cordless-Phone-Batteries/122830-Uniden/DXAI5588/1.aspx
8/29/2011 7:18:38 PM •
Uniden...
Answered
on Aug 29, 2011
How do I change my personal greeting on my
Press and hold the greeting key until you hear the prompt, release the button, then record your message at the tone. Press the greeting key again when done.
The full instructions are on page 39 of the manual at
8/29/2011 6:40:53 PM •
Uniden...
Answered
on Aug 29, 2011
1. I need the operators manual.
2. I need to know
1) You can download the manual from the manufacturer's web site at
2) Do it the old-fashioned way. Hold a recorder up to the answering machine while you play back the messages.
8/25/2011 6:11:48 PM •
Uniden...
Answered
on Aug 25, 2011
Answering machine is not answering
If your phone rings normally and your can make and receive calls, the line is OK, please check if answering option is on, typically a botton marked ANS or similar with an indicator or a display showing that it's on.
3/16/2011 2:05:37 AM •
Uniden...
Answered
on Mar 16, 2011
How to change the numbr or rings before...
1) With the phone in standby mode, press the menu/clock key three times.
You hear “Ring time” and the current ring time ([2 ], [ 4], [6 ], [T ] Toll
saver), and it is displayed on the main base. Then you hear the guidance for setting
the ring time.
2) Press the volume/select/ or up or down arrow key until the desired ring time appears.
3) Press the set key to select the new ring time. You hear a confirmation tone, then
the announcement “Ring time” followed by the new ring time. After a few
seconds, the system announces “To set record time, press menu again.”
Need the manual for your phone? You can download/print it here:
http://www.uniden.com/pdf/DXAI5588-2om.pdf
Bill B
3/4/2010 2:32:41 PM •
Uniden...
Answered
on Mar 04, 2010
I have a dxa15588-2 twin
Hi, it is absolutely impossible for you to register the TCX expansion handset with the DXA main base.....
I have tried experimenting myself as a phone expert but it didn't work..
Take care
2/20/2010 10:32:29 PM •
Uniden...
Answered
on Feb 20, 2010
How do you adjust volume on base ringer on uniden dxa15588-2
Setting the Main Base Ringer Volume
The main base has three ringer volume settings: high, low, and off. You can change
the ringer volume while in standby mode or while an incoming call is ringing.
1) Press the ringer key.
You hear the ringer at the current volume level
([ ] High, [ ] Low, [ ] off) (if you set the
main base ringer volume to off, “Ringer off” is
announced) and it is displayed on the main base.
2) Press the ringer key repeatedly until the desired ringer
option appears.
3) The system displays the new ringer volume.
12/31/2009 9:28:00 AM •
Uniden...
Answered
on Dec 31, 2009
