20 Most Recent Uniden DECT 6.0 Cordless Phone Questions & Answers
On a Samsung 7 phone i sent a text message last night to a number that was not on my contact list. This morning there was a bell shape icon with a vertical stash threw the bell. What does this mean.
Uniden DECT 6.0... | Answered on Sep 20, 2018
Since you declined to specify the model of your Uniden DECT 6.0 phone, select it from the list beginning here to download a copy of the manual.
Uniden DECT 6.0... | Answered on Jan 04, 2018
To turn off Silent Mode On use the # button. Press and hold until silent mode is turned off.
Uniden DECT 6.0... | Answered on Sep 27, 2017
does it have speaker phone option .
Uniden DECT 6.0... | Answered on Jun 07, 2017
If you have no dial tone the problem is most likely the base station has failed, nothing you can do will kill the dial tone (no button you pushed etc.) except a failed base station.
Uniden DECT 6.0... | Answered on Dec 19, 2016
You have asked this question four times. When you ask for the fifth time, PLEASE specify the model of your Uniden DECT 6.0 phone.
Uniden DECT 6.0... | Answered on Nov 11, 2016
To replace the default greeting with a personal one
( Uniden model D1680 & similar ):
1. press [MENU]
2. scroll to "Ans. Setup" then press [select]
3. scroll to "Record Greeting" then press [select]
4. It will display & tell you aloud to press [select]
5. Speak Clearly your desired greeting, then press [select]
6. press [END] to conclude & exit
Uniden DECT 6.0... | Answered on May 16, 2016
This sounds like the handset has lost its "registration" with
the base. De-registering & re-registering is often easy.
First, be sure the handset battery is well charged as a
weak battery will interfere with the registration process.
Then try this ( 'works for the D1680, D1481, & similar):
To deregister the handset:
1. Press and hold the [END] and [ # ] keys at the same time,
after a few seconds the display will say
"System Reset, Deregister Handset"
press [SELECT]
scroll to "Base Unavailable"
press [SELECT] (chirps) press [END]
display reads "Place in base..."
Next, to re-register the handset:
2. Set the handset into the base cradle and wait,
within ~30 seconds the handset should display
a "Handset #" and be good to go...
If you mean the PIN to access voicemail remotely it can be reset only from the base unit. Instructions from Uniden Answering Machine
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Uniden DECT 6.0... | Answered on May 15, 2016
The handset cannot communicate with its base.
When the handset cannot establish its secure (encrypted) radio
link with the base it is 'paired with' or 'registered' to, it will first
say "Connecting....", then it will display "Out of Range or No
Power at Base", then it settles at the infamous "Searching..."
display.
Although rare, the registration between base and handset can
become corrupted and lost so that we must de-register and
then re-register the pair.
First, ensure that power is 'on' at the base (a more common cause)
and the cradle will charge the handset, etc.
Second, be sure the handset battery is well charged as a weak battery will interfere with the registration process.
Then try the following ( 'works for the D1680, D1481, and similar):
press [SELECT]
after ~30 seconds the handset should display
or it will display "Registration Failed"
Uniden DECT 6.0... | Answered on May 13, 2016
check the base station
Uniden DECT 6.0... | Answered on Mar 24, 2016
You need to contact your telecom provider as they are responsible for transmitting your phone number, not your home phone.
Uniden DECT 6.0... | Answered on Mar 18, 2016
Uniden DECT 6.0 Cordless Phone Logo
389 questions posted
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
Uniden Lands Phones
  • Uniden Lands Phones
Most Popular Question
silent mode
  • Lands Phones
