SOUND AND OTHER OPTIONS ARE LOCKED AND I CANT SEEM TO FIND A CODE OR CODES FOR MY XFINITY OR PHILIPS REMOTES. OR IS THERE A WAY TO RESET IT TO FACTORY SPECS ? PLEASE HELP I GOT THIS FOR MY KIDS ROOM AND DONT HAVE MONEY TO BUY ANOTHER. PLEASE HELP IF YOU CAN. THANKS
To do a factory reset, you must have its original remote control. A universal remote won't go. If you have its original remote control, and want to know more, check the site linked here. http://electronicshelponline.blogspot.com/ You have to enter its service mode option to make it a system reset. Never attempt to do it, if you are not sound in electronics. Pull up previous posts, either by type in the Brand name to your set in its search box, or view it in Mosaic / Timeslide / Flipcard option.
SOURCE: remote codes for "ph301s" universal philips remote
www.remotecodelist.com .............................T.
SOURCE: Universal remote codes for a conia tv?? Help me PLEASE :)
Forget it...just found the code...hey leighxo, if you happen to have a Tevion universal code like me, try 0229 - its a long shot but hey...
GE ........... 0704 0312 0018 0002 0502
................. 0006 0007 0601 0835 0901
................. 0114 0103 0803 0806 0310
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
SOURCE: I need Philips CL035A codes list for toshiba tv
I believe this is your remote. it's listed as pm435s
http://www.p4c.philips.com/files/u/us2-pm435s/us2-pm435s_dfu_eng.pdf
these are the codes for toshiba
0517, 0419, 0512, 0613, 0719, 0112, 0506, 0111, 0618, 0627, 0437, 0041, 0094, 0802, 0111, 0313, 0715
You can format your Nokia N70 device by typing: * + 3 + call + Power on. Before the device is reset, you need to provide the lock code. The default lock code is 12345.
If it is not working try this code:
You can format your device by typing *#7370# in standby mode. Before the device is reset, you need to provide the lock code. The default lock code is 12345.
Some Nokia phone can be reset via this menu option
Press menu button or enter Menu > Settings > Phone > Phone management > Factory settings > Delete data and restore > YES
NOTE: Before you proceed with the Factory Reset, enter a four-digit access code. The Factory Reset and
Parental Control always share the same access code. The default Parental Control code is 3355
NOTE: Parental Control setting can be reset by doing factory reset
If you ar unable to do this proceedings, do the unlock method used for Philips, and your TVs kit is of Philips.
Philips sets use a four digit code to control the v-chip. The override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset.
OK.
