Question about Dell W4201C 42 in. Plasma HDTV
Key lock on - Dell W4201C 42 in. Plasma HDTV
Posted by zaraanam on
    Top Expert:
  • Dell Master
  • 76,416 Answers
Hello
Your Dell tV can be unlocked by reseting it to factory reset.
To reset it to factory reset do the folloing.
Enter the TV main Menu.
Select Factory Reset to return the TV Menu settings to the factory default values
NOTE: Before you proceed with the Factory Reset, enter a four-digit access code. The Factory Reset and
Parental Control always share the same access code. The default Parental Control code is 3355
NOTE: Parental Control setting can be reset by doing factory reset
If you ar unable to do this proceedings, do the unlock method used for Philips, and your TVs kit is of Philips.
Philips sets use a four digit code to control the v-chip. The override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset.
OK.
Posted on Feb 01, 2011
We had to cut a lock off and that lock goes to other enclosures I just replaced the locks. Are you able to replace that similar lock? I want it keyed alike with the other locks
either buy a set of locks that are keyed alike a few places carry bulk locks --or buy locks that can be keyed to what ever key you want call a locksmith and ask for places to buy bulk verses interchangeable tumbler locks
Aug 18, 2016 | Brinks 1-9/16 In. Brass Long Shackle...
I am to turn a key 1/4 turn beforekeying the lock. With a key in the lock it will not turn @ all, so a=cannot key my lock.
If you can get access to the inside of the door, the lock can be removed. Be sure you are using the correct key - try all the Kwikset keys you have. If you're completely locked out, you might need to call a locksmith.
Jul 01, 2014 | Kwikset Locks & Locksmithing
Locked
Press and hold the key programmed as
[Key Lock]
for
2 seconds to lock the transceiver keys. Press and hold the
[Key Lock]
key again to unlock the keys.
LOCKED
appears when a key is pressed while the keys
are locked
Mar 05, 2014 | Kenwood Radio Communications
Unlock number lock
On a laptop, the "Num Lock" key has a function slightly different than the one it performs on full-d desktop keyboards. Activating "Num Lock" on a laptop usually transforms a set of central keys, including many letters, into number keys, allowing typists used to entering numbers on a keypad to type efficiently. While on desktop keyboards "Num Lock" usually has a dedicated key, on laptops it often shares a key with another function on MacBooks, for example, it shares the "F6" key and you must hold down the "Shift" or "Fn" key to activate it.
Look for the "Num Lock" key on your laptop's keyboard. This is usually near the top of the keyboard. If the key says nothing on it except "Num Lock" if that's the only function the key performs you can just press it to activate the lock; a light will probably go on somewhere to indicate that "Num Lock" is on. If the key has multiple functions, you'll have to hold down a different key while pressing it. Hold down "Shift" and press "Num Lock" if the writing saying "Num Lock" appears above some other writing on the key, the way various symbols appear above the numbers on the keyboard's number row. Hold down "Fn" and press "Num Lock" if the writing saying "Num Lock" appears in a different color often light blue that's shared by the "Fn" key.
Feb 28, 2013 | Acer Aspire Computers & Internet
Just bought 1979 firebird at auction. Cannot lock ignition with key. Is my problem most likely: a) incorrect ignition key b) faulty ignition lock c) steering column locking mechanism FYI - door locks...
u can start but the key will come out the key could be woren out or ingnition lock could be bad pull sterring wheel get a tool to press the lock plate down with to get clip off then take screw out sign pull it out then there a star screw take it out pull lock cylinder out put new in put back to gether
Feb 08, 2011 | 1979 Pontiac Firebird
Have a 1993 accord only key i have is ign. what does key for back seat release and shift lock and gas lock look like ?
The door lock key is the one that's used for all the locks you mentioned. If your ignition key does not work on all the locks, maybe someone, somewhere along the life of your car changed the ignition cylinder and never gave you the original key for the car, which would have operated all the vehicle's locks. Also, any one of those keys can be used to unlock the shift lock since once a key is inserted fully all the way down in there, the shift lock is released.
Feb 04, 2011 | 1993 Honda Accord
I have replaced the batteries on the key remote control but it does not work
Programming
When
Key added or replaced. System malfunction.
How
Obtain all keys. A maximum of 3 keys can be programmed. Close all doors and boot/tailgate. Switch ignition ON. Repeat procedure below 3 times: Within 4 seconds: Press key lock or unlock button. Within 4 seconds: Switch ignition OFF. Within 4 seconds: Switch ignition ON. Within 4 seconds: Press key lock or unlock button. System should now lock or unlock vehicle. Within 4 seconds: Press key lock or unlock button. Within 10 seconds: Press lock or unlock button of first key. System should now lock or unlock vehicle. Press lock or unlock button of second key. System should now lock or unlock vehicle. Press lock or unlock button of third key. System should now lock or unlock vehicle. Switch ignition OFF. Remove key. Check operation of all programmed keys.
NOTE: If less than 3 keys are to be programmed, remove ignition key after programming last key.
Mar 22, 2010 | 2005 Honda Accord
Central locking on mk 5 golf works fine with key in lock and from inside car using switch but only unlocks drivers side using key fob. any answers?
Synchronization
When
Key buttons operated repeatedly while vehicle out of range and system becomes inoperative.
How
Polo: Press key unlock button for approximately 1 second. Golf/Bora: Press key lock or unlock button for approximately 1 second. Manually lock or unlock vehicle. System should now lock or unlock vehicle. If not, carry out programming procedure.
Programming
When
How - Polo
Keys can only be programmed using diagnostic equipment.
NOTE: A maximum of 4 keys can be programmed.
How - Golf/Bora
98MY
How - Golf/Bora 99MY
Switch ignition ON. Insert key to be programmed into driver's door lock. Lock vehicle manually. Press lock or unlock button. Wait at least 1 second. Press lock or unlock button again. Vehicle horn sounds to indicate correct programming. Keys can also be programmed using diagnostic equipment.
Mar 07, 2010 | 2001 Volkswagen Golf
I have a 2004 Honda Accord EX. Key Fob works trunk but not doors
Programming
When
How
Jan 25, 2010 | 2004 Honda Accord
Dell W4201C 42 in. Plasma HDTV Logo
4,027 people viewed this question
Top Dell Televison & Video Experts
CoppellTVRepair.com
Marvin
Marvin
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
