There is a leaf switch inside the loading mechanism, which detects the tray to fully closed state. If this switch has damaged, this kind of fault will occur. To repair it, you have to open the set, and take the loading mechanism out, and disassemble it. If you wish to get some details, check the site linked here.Pull up older posts.
Open up your new email type in the adress then you should see attachment depending on which email you are using select attachment then you will open up a browse window navigate to your Files select it you might have to wait a few seconds for it to load as an attachment then click send Hope this helps.
Hello
There are three possibilities for this trouble with this DVD player. The first one is imprper loading function due to loading motor or loading belt trouble. If loading motor is weak [that is its pulling power has gone low] the tray will not close properly into the mechanism, and will not touch the load sensor switch fitted inside the mechanism. If this happens, the main system control IC will detect improper loading and will turn the tray out again to load it properly. Just try to close it without a disc inside the tray, and check whether it closes well. If it does so, or the trouble repeats, change the loading belt first. In most cases, this will retify this type of trouble.
The second one is, bad 'Sled' motor. sled motor is one, which spins the disc inside the mechanism. After proper loading, if the disc do not spin inside it, again the system control IC will sense it, and will eject the tray. The sled motor also is a replacable part.
The third one is, damaged gear wheel in the loading gear section. to detect and repair any of above trouble, you have to open your DVD player, and take the DVD mechanism out of it, and is somewhat semi-skilled work indeed. Check these first. If you want anymore assistance from me, feel free to get be by fixya. If you are somewhat skilled, and have confidence and can follow the diagrams, send your email address to me by FixYa. I'll send the service manual of your DVD player by return mail. All details and disassemblng procedure are in it. OK
Hi there, after open internet explorer click tools option. From there select internet options and there you found a option" delete temporary internet files, history, cookies. " Just delete them & then close the internet explorer. After that go for email reading the page will open. Thanks & waiting for your feedback.
I think your mobile is affected by virus. I suggest you to format your memory card and flash your phone. Dont use the backup you have taken other than the contacts. Load other things manually and frehly. hope this helps.!!
one of the best and simple solution is that u should install new window and then without opening a any drive install an antivirus than scan all the drive. your problem will be solved
Open Internet Explorer. Press [Alt] + [T] + [O] Choose the Advanced tab from the menu. Click on the [Reset] button below the Reset Internet Explorer Settings b section. Close Internet Explorer. Remove all versions of JRE (Java Runtime Environment). Install JRE 1.4.2_08 Open Internet Explorer and open the Yahoo mail page. Hopefully you should now be able to compose new mails and view the existing emails.
