Working great for many years and suddenly the picture went out and the sound was ok. Unplugged everything and re-plugged the power. Now there is no power and no sound. Is there something simple to try first before I call in the experts? Is there a fuse or something I should be looking at?
SOURCE: TP50G90 no power
sounds like something in the standby voltages most likely a regulator or leaky diode causing the problem.
SOURCE: TOSHIBA TV NO SOUND NO PICTURE, POWER LIGHT IS ON
the lamp in the projector might have went. try replaceing it. to do so try
ADTECH SYSTEMS they may help
there in mass.
call David Crepeau at 978 261 1087 tell him Ryan Bolduk sent you
depending where you live. They maybe able to send someone out from there sub company
SOURCE: The red power on light just blinks. Tried leaving it unplugged. Still didnt work
Ours was doing the same thing, we changed 3 little black fuses in it and it works. I do believe they are 5 amp but not positive, we found them through a tester. When I have the exact answer for u I will email u again sorry u have had no response till now probably does you no good now..It's been awhile since they were changed.
SOURCE: red power light continuously blinking. no picture no sound.
It could be the lamp went out and needs replacement. The Toshiba website states when this happens to unplug the televison for 10 minutes then plug back in. If that does not work then try another power outlet. If that does not work then call for service
SOURCE: Toshiba tz43v61 TV just died. No red light.
does it have a power strip on the tv stand? if so plug the tv into a wall socket.my power strip went bad and the reset button did not work
