20 Most Recent
Sony KV-27V22 TV Questions & Answers
I have a ten year
most likely it needs repiars, (replacement of capacitors in the power-supply.)primary and secondary side.
Or loose conections (dry joints)
Sony KV-27V22 scrambled picture and loud buzzing audio
the variation from higher channels from lower channels, few things changes eg frequency, voltage, and current.
take your tv to a w/shop and have the following
tunner voltage pulse variation on a avo meter has you change channels. if the difference of voltage is not unform when you are changing from to channel then you should change the control ic on the rf stage or check the capacitors a round the rf ic for variations in value.
Sony Trinitron color TV model no. kv-27v22
dear, you can check that transformers out put before connecting to a tv. also when its connected to a tv.
get a avo meter and connect in series with a tv.
observe the current on the intial switch on and when the picture goes. if you notice that current on intial switching is high and then it starts going lower and lower, then change the transformer.
but if the current starts going up from the intial current then check the power supply components of the tv.
thanks for asking fixya.
Burnt electronic smell even hours after tv turned off
Its behavior is not normal. Have it repaired. Fumes are hazardous to your health especially to the little one's health. Think of a fire hazard too. As the adage says :No fumes without fire.
Hope you decide to be rid of the bomb or have it repaired.
No picture, sound works on Sony TV KV-27V22.
try to adjust the screen. it is located behind the CRT board.(CRT board is the board that attached to the picture tube) you will find a black knob which label screen adjust it by turning the knob.
Sony trinitron KV27V22
Solder any / bad connects horiz,vert and power supply then
try again....................T.
Please rate this solution.........................
maybe there is a contact error in power supply or the deflection stage. If the resoldering does not help-
here are some possible solutions:
remedy
Replace flyback location LP04.
Entered for KV32S22 /SONY (Chassis)
remedy 2
Replace IC351, Q602, Q601 (2SC4834M), R607 (1R/0.5W), R622 (10R), IC641 (SI3090CA) and Q502 (2SC5148).
remedy 3
Replace tuner.
remedy 4
Replace R607, Q502 and IC601.
remedy 5
Replace regulator IC, R607, check C609, C610 (0.68pF) and C613 (0.0022pF/500V).
remedy 6
Replace horizontal output transistor (2SC5148), IC601 (MX0841) and R607 (0.1R).
remedy 7
Replace IC1701 and IC601.
remedy 8
Replace Q501 (2SC5148), R607 and resolder horizontal driver transformer.
remedy 9
Check and replace horizontal output transistor Q502 (2SC5148) and IC601 (MXD8411AB-F).
remedy 10
Replace shorted R607. Also check T501 and Q501 for dry joints.
remedy 11
Replace C608.
remedy 12
Replace Q602 and D648.
remedy 13
Replace Q502, Q601, Q602 and R602.
remedy 14
Replace D626 (6.2V).
remedy 15
Replace IC801 and R607.
remedy 16
Replace horizontal output transistor and the associated damping capacitor. Check flyback transformer and SMD microprocessor as well.
remedy 17
Replace R639 (4.7R/0.250W) located on G board in standby power circuit.
remedy 18
Replace D600.
remedy 19
Replace C502 (0.47uF/50V).
remedy 20
Check D655(1N4937), D657 (1S1834) and Q601 (2SC4423).
remedy 21
Check D606 for leakage.
remedy 22
Check yoke between vertical and horizontal windings for S/C.
remedy 23
Replace Q601 (2SC4834MNP), R607 (0.1R) and C517 (2.2uF/250V).
remedy 24
Replace R611.
Kp-46wt510 rear projector from sept. 2003
You have a failure in the convergence circuit.
There's a circuit board ( the convergence board) which has 3 IC'c on it that drive yokes on each of the picture tubes red-green- blue.
You probably lost power to these IC's or one or more may have opened up. Sometimes poor solder joints on these IC's will develop causing loss of convergence.
Hope this gives you an idea as to where you problem is.
Stargazer
Sony kv27v22 TV
check horizontal drive tramformer for intermitance is common problem some time blows horiz transistor to or vertical IC intermintence to
Sound no picture on cable
sweetkiss, if it works through the dvd player and not on cable/satellite box then the tuner is bad, if you have any type of cable/satellite box try running A/V cables out of the box to video input on the back of the tv and switch the tv to that video input, ie; vid 1, vid 2 etc. (your using one of those inputs for the dvd) this will give you your picture back, you can of course also replace the tuner in the set, good luck, BMW Rider
Sony Trinitron: No Picture
It is likely the HOT (horizontal output transistor) and a couple of associated capacitors.
common failure.
the HOT is around 8.00 and some for the caps.
but almost no tv person works for less than 100. and provides a warranty. so you can expect 150. at least for a bill.
Sound, but no picture
Locate vertical output IC = solder all pins = two off-set rows,
then try again................part location IC301 , or 401 ?
2) possible bad CRT = turn up screen voltage slightly = did pix pop back on ?..................................T.
