Trying to set up blu ray to the hitachi tv
SOURCE: hitachi remote CLE-967
Hi.
I wrote an article on how to repair remote controls.
You will find it here.
http://www.ehow.com/how_2094701_tvvcrcabledvd-remote-control-quick-easy.html
Chris.
SOURCE: am trying to find out
Go to your local appliance stockist and see if they can order it in for you,try the agents for Hitachi inyour area,
failing that there are unversal learning remotes available for any reputable stockist for your model.
Hope this helps
SOURCE: Black Bars on all blu ray movies
Hi icmjrtdr,
Having black bars displayed when watching a Blu-Ray disc is a common occurrence, even with a widescreen television.
You may have heard or seen aspect ratios of 4:3 or 16:9. 4:3 is the ratio of a traditional television that is nearly square. 16:9 is the ratio of most widescreen televisions currently marketed. The reason that even with a 16:9 television Blu-Ray discs are displaying black bars is that many of these discs contain footage that has not been reformatted for television. The screen in a movie theater is even wider than 16:9, and rather than trim the ends, most Blu-Ray discs maintain the entire picture.
Depending on the options available in your particular television, you may be able to find a zoom setting that trims the ends and removes the black bars. It is up to you if you would rather see black bars with the entire picture or lose a small amount of the picture on each side for a full-screen experience.
Hope this helps,
Jason,
Go Ahead. Use Us.
SOURCE: Remote Control codes to control other brand devices
i have sony receiver codes 31759, 30158, 31758,
or 4 digit codes 0158 and 1758
SOURCE: vizio tv code for sony blu-ray disc player ''remote''
I put the Mitsubishi code, 04 as well for my visio 22 inch LCD. Worked just fine now!
