Televison & Video Logo
Question about Hitachi Televison & Video
Hitachi cle 1018A tv remote replacement remote
Where do I purchase a new tv remote for our Hitachi CLE 1018A
John Osborn
For replacement of Hitachi TV remote controls under warranty, including CLE-1018A (for TV model DF4000DV and perhaps others), you need to contact Tempo Australia, phone 02 9975 2199 or 1300 886 649 (you may need to stay on the line for more than 15 minutes before you can talk to someone). Hopefully they can also advise you on purchase of a remote control if you are not making a warranty claim.
Posted on Jan 15, 2014
5 Related Answers
Anonymous
  • 372 Answers
SOURCE: hitachi remote CLE-967
Hi.
I wrote an article on how to repair remote controls.
You will find it here.
http://www.ehow.com/how_2094701_tvvcrcabledvd-remote-control-quick-easy.html
Chris.
Posted on Nov 21, 2007
Anonymous
  • 2712 Answers
SOURCE: remoet control fro my hitachi plasma tv, wont sitch on /off but does other options
You can find the remote control codes for difrent brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 02, 2008
Anonymous
SOURCE: tuneing in my tv
Hi There
Came to this site with the same problem - finding no answers I went back and tried again
Hope this isn't too late for you. Press the 'MENU' button - you'll get the picture sound etc - keep your finger on it and you get 'INSTALLATION' at the bottom in white!
Hey presto! use the <&> to get into the sub menu and away you go!
Hope this was some help
(P.S. use the menu button on the front of the set if the remote button fails to bring up the installation option = it is behind a flap between the on/off button and the indicator lamp under the screen)
Posted on Jun 28, 2008
yourtruck
Chad Watson
  • 37 Answers
SOURCE: Enter channel number of double digits?
Are you being serious? Are there numbers on the remote? press 02 for channel two press 08 for channel eight press 10 for channel ten all the way up to 99 then back again.
Posted on May 30, 2009
Anonymous
SOURCE: manual tuning of Hitachi cle-942 tv
Select the channel to tune & press "CH" this is the key to the right of zero on the CLE-942 remote, Now you can tune the selected channel. You also need this key to sort/move channels after running auto tune.
Posted on Aug 29, 2009
Hitachi CLE 980 remote is not working. Wont turn the TV on no buttons are working. Have changed batteries still not working
Either the remote is fubar or the receiving circuits on tv are fubar. There is a way of checking a remote with a digital camera. - Google it and see what the story is.
How to return to TV from USB setting Hatachi cle-1018A
You should press SOURCE on Remote and select TV
The on off button on the remote control. All other buttons work.
new remote needed probably also try unplugging tv from wall socket for ten mins then retry remote failing that
www.genuineremotes.co.uk for a new remote
My hitachi CLE-993 is not working on my TV but there is a red light on the remote every time I press any key...What should I do??? Please help...Thanks
I am also facing the similar problem with CLE 999, LCD is not functioning !!!
Anybody knows to rectify, pls. provide solution.
Rgds, PK
2helpful
Hitanchi cle-922a instructions
I need a manual for my Hitachi CLE-922A remote control. plz help! ..Bob
1helpful
Manual tuning of Hitachi cle-942 tv
Hitachi CLE-976 problem.
The CLE-976 was no a cellular phone but a remote control for a Plasma TV. I contacted Hitachi Australia who put me into contact with a company that sell spares.
Thanks
1helpful
Hitachi cle-990
not sure your model number is correct please check here is a manual for the 42 CL plasma TV http://www.hitachiserviceeu.com/scripts/userguide.php/CL42PD2100_EN.pdf if it is a different set please check the model number, this should have a 42 in it (as it is 42")
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
