Sometimes screen does not respond until touching around with the stylus, when touching a digit or an alphabet, something other than the place you touched comes up.
My Palm TX was purchased in St Laurent, Montreal and I forgot the company name, over a year ago.
Have you tried touching the screen with a pen, or stylus. Or even your finger nail? My KORG does not work well with fingertips, needs something harder.
Sounds like you should try recaliberating the touch screen. Calibration must be done with a stylus. Please note: Using a unlicsensed screen protector can lower the sensitivity of the screen, making calibration difficult. If the problem you are encountering started happening after installing a screen protector, this may be the cause of the problem. Remove all games from the Nintendo DS. Turn the system on by pressing the POWER button. Press the A Button when the "Touch the Touch Screen to continue" message appears. When the main menu appears, use the Control Pad to to place the cursor over the Settings Menu Panel at the bottom of the screen, and press the A Button. should look like this :
Use the Control Pad to place the cursor over the orange icon that looks like crosshairs (the right-most icon), and press the A Button. should look like this:
Use the stylus, and tap the red square that appears on the screen. Do this each time the square moves. You must touch the red square precisely at each of the three positions, otherwise the test will continue to re-start If the touch screen is not responding properly, hold the Nintendo DS at an angle so that you can see where the edges of the Touch Screen meet the housing of the system. Look around the entire edge of the Touch Screen for any foreign material (such as crumbs, etc.) that may be wedged in between the Touch Screen and the housing of the DS. Foreign material in this area can cause the Touch Screen to work incorrectly. When complete, four squares will appear, allowing users to test the touch screen sensitivity. (Testing is optional.) Tap the "Confirm" button in the lower-right corner. Wait for the the confirmation message to disappear, then tap "Quit," then "Yes" to exit. The unit will shut down automatically to save the settings. hope this helps
For the touch screen to work properly, the screen has to be absolutely
clean. From the description, it is evident that the issue is confined to
one particular corner of the screen, and any button appearing on that
part is not responding to touch. This means that the screen is not clean at that portion. Clean the screen using a good quality micro fiber cloth. Make sure that the screen is absolutely clean and try using with a clean finger or stylus (Sony calls it Paint Pen or Touch Pen).
Try recalibrating the touch screen. Devices with touch screens need to be recalibrated in order to respond properly. The greater the use, the more often recalibration is necessary. I recalibrate my phone once a week. I hope this helps.
Hold the Sleep Button and the Home Button at the same time for 10 seconds. The screen turns off, wait for 5 seconds. Then hold the power button again until you see the Apple Logo. Wait for couple of seconds. Then your problem should resolved!
Be sure that you're using only the bottom screen of the Nintendo DS Lite with the stylus. The upper screen is not a touch screen.
Unlicensed screen protectors can lower the sensitivity of the touch screen. If the problem you are experiencing started happening after you attached a screen protector, you may want to remove it. Please note that some screen protectors can leave behind a residue that may be difficult to clean. If you are planning on removing a screen protector that has been placed on your Nintendo DS Lite
If the touch screen is not responding when touched, or the accuracy of the screen is off, you may need to recalibrate the touch screen.
You must touch the red square precisely at each of the three positions, otherwise the test will continue to re-start.
If the touch screen is not responding properly, hold the Nintendo DS at an angle so that you can see where the edges of the Touch Screen meet the housing of the system. Look around the entire edge of the Touch Screen for any foreign material (such as crumbs, etc.) that may be wedged in between the Touch Screen and the housing of the DS. Foreign material in this area can cause the Touch Screen to work incorrectly. If there are any visible particles, clean the screen.
If the above steps did not help, there is a problem with the system and it will need to be repaired.
Hi penny_od.....The following excerpts has been extracted from the Nintendo Help Site. If you would like to view the entire document, please click on the URL below....Please update your post of any progress, whether positive or negative so that I may learn from this too.....good luck my friend.
http://www.nintendo.com/consumer/systems/ds/trouble_screen.jsp#touch
Touch Screen doesn't respond or is inaccurate when touched
* Be sure that you're using only the bottom screen of the Nintendo DS with the stylus. The upper screen is not a touch screen.
* Use only licensed Nintendo DS styluses and screen protectors.
* Unlicensed screen protectors can lower the sensitivity of the touch screen. If the problem you are experiencing started happening after you attached a screen protector, you may want to remove it. Please note that some screen protectors can leave behind a residue that may be difficult to clean. If you are planning on removing a screen protector that has been placed on your Nintendo DS, click here for tips on cleaning your screens.
* If the touch screen is not responding when touched, or the accuracy of the screen is off, you may need to recalibrate the touch screen. Click here for help recalibrating the Touch Screen.
* If recalibrating the screen didn't solve the problem (see above step), hold the Nintendo DS at an angle so that you can see where the edges of the Touch Screen meet the housing of the system. Look around the entire edge of the Touch Screen for any foreign material (such as crumbs, etc.) that may be wedged in between the Touch Screen and the housing of the DS. Foreign material in this area can cause the Touch Screen to work incorrectly. If there are any visible particles, please follow these steps for cleaning the screen.
If the above steps do not solve the problem, your system will need to be repaired. Click here for repair information.
the same. touchscreen is way off.
