Posted on Mar 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cannot communicate with twain devise
Standard PC running windows XP Pro. I am connecting to a Brother MFC 620cn.When using paperport or the brother control centre I get the error message "cannot communicate with twain device". If I go to control panel,
Scanners and camera's, locate the scanner then I can scan but not in OCR or PDF
Anonymous
Level 2:
Scholar:
  • Expert 42 Answers
  • Posted on Mar 23, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
42
Questions
0
Helped
13326
Points
147
I suggest using ISIS drivers instead of TWAIN. I have always had trouble with the twain drivers failing especially in paperport ive found the ISIS drivers to be much more stable.
If you do require TWAIN though best way to fix is un-install the software that the TWAIN driver came with and re-install it. Unfortunately thats the easiest solution.
If you want to try the isis drivers they should be on the cd that you used for the twain drivers just select isis instead.
Let me know if you need further assistance.
How di I reinstall PaperPort Print Driver? PaperPort 11, Windows 7
Instructions extracted from http://social.technet.microsoft.com/Forums/en-US/w7itproappcompat/thread/f903e1ed-e15b-4cb6-a20a-50f628f95939
"{Ok, here is how I got the whole package from my Brother MFC and PaperPort 11 with the printer utility.
First if you have tried to install the suite or paperport and are having issues uninstalling through windows download this wonderful program that removes everything called Revo Uninstaller at www.revouninstaller.com and choose the freeware version.
Now go to the Brother website and search for the Windows 7 MFLPRO Suite and you should download a zip file that contains the suite for multiple MFC’s. Unzip it and set it aside. This is only the Brother Suite for the Brother MFC and the Control Center 3.
TO find the Windows 7 version of MFL PRO go here
http://www.brother-usa.com/downloads/default.aspx?ProductGroupID=5
PaperPort 11 will have to be installed from the actual CD that came with your printer. Inside the CD with Windows Explorer File System locate the file Inst32.exe that should be inside the CD under the install folder then MFC-465CN (my model) then usa folder. Remember the location.
Now set everything aside and let’s start. Open up control panel, click on programs and features then choose Run programs made for previous versions of Windows. You have just opened up program commutability, now click next and wait now choose not listed and press next. Browse and fine the Inst32.exe file that I mentioned earlier. Now click next and then choose Try Recommended Settings, Next your setting should say applied and compatible with Windows XP SP2, then you will see a tab on the next screen that says Start the program. Click on it and allow it to start installing this will start the suite and the first thing that installs is PaprPort, be patient let it continue to run and after it will install the PaoperPort print driver, then after it will start into the MFL PRO Suite. This is where my installation halted because the suite is a 32Bit version it would not continue. I looked and PaperPort program and printer where installed. Close it up and pres next.
Finally now you can install the MFL PRO for Windows 7. Open up the folder you downloaded from Brother and look for your model and you will see the setup.exe application, click on it and start installing MFL PRO along with Control Center 3. That’s it, and your setup should be complete.}"
Hope the thread from http://social.technet.microsoft.com/Forums/en-US/w7itproappcompat/thread/f903e1ed-e15b-4cb6-a20a-50f628f95939
will help.
1helpful
OCR problems for Brother MFC-8660DN with Vista 64bit
You are correct in that paperport 9 will not work on Vista and paperport 11 is the alternative. I called about a similar model and the guy at Brother told me that paperport 11 is included on an updated cd from brothermall.com for some models. It was only about $3 so you might want to check for your model. Hope this helps.
2answers
Brother MF-8440 scanner driver and document manager for Mac OS X
Open preview and go to file and then scroll down to "import from scanner" MFC should show up as a choice and then when the window appears, go ahead and pick your preferences and scan
Problem reinstalling Brother MFC 8440D.
uninstall the brother software for this machine, then reinstall the softeware. the paper port some times will install automaticly or you may have to click on iy to indtall. brother tech
Brother mfc 240c
you have to install the paperport software. This should be done when you have run the whole mfl-pro suite.
go to progr. /scansoft/paperport/ click scanner and simply scan into the paperport desktop.
I cant scan
You have to connect the mfc directly to a USB port of your computer. DO NOT use a hub.
The mfc uses the XP buil-in scan driver.
Did you install the whole mfl-pro suite? Use paperport to do scanning from your pc.
PC faxing
you have to install the mfl-pro suite given to you by cd. After installation go to START/PROGRAMM/BROTHER/PC-FAX SETUP (Guess you run windows). Or simply use the paperport software: drag your document and drop it to the faxsymbol. If you dont have it, download (153mb) from brother homepage of your country. Pleas notice: the faxprinter of xp wont work anymore after installation of the brother drivers (but you have the bro drivers then installed for fax :) )
Norman Weimar
Norman Weimar
k24674
