HEADLIGHTS WONT TURN OFF WITH SWITCH ON A 2002 FORD ESCAPE
Do they stay on with high and low beam? If high or low beam make a difference then you likely need a multi-function switch. If they stay on regardless of high or low beam your Daytime Running Light Module (DRL) may be faulty. It should be located on the rad support, ahead of the radiator. Once you located it, unplug it and see if your lights go out. If they do, replace the DRL. If they do not you likely need a headlight switch.
